HP Designjet T1100 and T1120 MFP Series Products - Mirror an Image
Mirror an image
Selecting the Mirror option before pressing the Copy or Scan button will mirror the image during input.
The Mirror option can be applied with both copying (from the Copy tab) and with Scan-to-file (from the Scan tab).
Mirror the image with copying and with scan-to-file
  1. Insert the original into the scanner.
  2. Make all your settings for the job in the Copy tab or the Scan tab.
  3. If you are copying, select: Copy tab, Settings, Mirror, and press OK. Then press the Copy button when ready.
    For Scan-to-file select: Scan tab, Settings, Mirror and press OK. Then press the Scan-to-file button when ready.
Country: Flag Bulgaria
