Document ID: c01203994
Version: 1
iPAQ H3900 Series may have duplicate menu entries after restoring a back-up file
Release date : 04-Oct-2002
Last updated : 11-Oct-2002
DESCRIPTION
After restoring a back-up file onto your iPAQ H3900 Series Pocket PC, the iPAQ may have duplicate entries in the Start Menu.
If you attempt to uncheck the duplicate menu entries from Start\Settings\Personal\Menus, the iPAQ may display the following error message: "Unable to move that item."
This issue will usually occur if you restore a backup file after the iPAQ has received a full reset.
sourceInformation
SCOPE
All iPAQ H3900 Series Pocket PC's may experience this issue.
RESOLUTION
If you have duplicate items in Start\Settings\Personal\Menu's, you can do the following set of steps that will allow you to remove the duplicate entry:
  1. Make a list of the duplicate items that are in Start\Settings\Personal\Menu's
  2. Open 'File Explorer' (click Start - Programs - File Explorer)
  3. Open the My Device\Windows\Start Menu directory
  4. This directory contains shortcuts to programs that are displayed in the Start Menu. The entries shown here will be listed once even though they are displayed twice in Start\Settings\Personal\Menu's. Referring back to your list created in Step 1, carefully select and delete only the applications that are displayed in duplicate Start\Settings\Personal\Menu's.
  5. Perform a Normal Reset
  6. Open 'Menus' (click Start - Settings - Menus) and verify the applications you want to be shown in the Start Menu has a check mark.
Downloadable Solutions
Downloadable File
Location
NONE
REVISION HISTORY : Release Date: 2002-10-04 Document ID: MH020923_CW01
Hardware platforms affected : HP iPAQ h3900 Pocket PC series
Operating systems affected : Microsoft Windows for Pocket PC 2002 (deleted)
Support Communication Cross Reference ID : IA01203994
Country: Flag Bulgaria
