    Fix Windows 10 Update Issues
HP Pavilion w2207h Monitor - Product Specifications
The document applies to the HP Pavilion w2207h monitor.
The HP Pavilion w2207h is a 22-inch wide-screen flat panel monitor with liquid crystal display (LCD) and thin-film transistor (TFT) screen.
Figure : HP Pavilion w2207h LCD wide-screen flat panel monitor
GM757AA
Features
The HP Pavilion w2207h LCD wide-screen flat panel monitor has the following features:
  • BrightView Technology enhances clarity and provides brilliant colors
  • 1680 x 1050 factory-set resolution
  • Video inputs supported:
    • VGA analog signal
    • HDMI digital signal
  • USB port (on rear of panel). Ability to connect up to two USB devices, such as a USB flash drive or a digital camcorder, to monitor.
  • Supports High-bandwidth Digital Content Protection (HDCP) to prevent transmission of non-encrypted high definition content
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Star compliant
Technical specifications
LCD feature
Specification
Display size
22-inch (55.9 cm) diagonal and viewable image
Display type
Thin-Film Transistor LCD active matrix
BrightView technology
Input terminal
VGA 15-pin D-type connector
HDMI connector
Scanning frequency
Horizontal scan range 24-82 KHz
Vertical scan range 48-76 Hz
Recommended resolution (H x V)
1680 x 1050 @ 60 Hz
Contrast ratio
up to 2000:1
Dynamic contrast ratio
up to 3000:1
Response time
5 ms (on-off)
Pixel pitch
0.252 mm
Power source - AC/DC adapter
Input rating: 100 to 240V~
Power consumption: <65 W in operating mode, <2 W in sleep mode
Operating environment
Temperature: 41 degrees F to 95 degrees F (5 degrees C to 35 degrees C )
Humidity: 20% RH through 80% RH (non-condensing)
Storage environment
Temperature: -4 degrees F to 140 degrees F (-20 degrees C to 60 degrees C)
Humidity: 5% RH through 95% RH (non-condensing)
Dimensions
H x W x D, including base:
18.9 x 20.5 x 11.3 inches (48.1 x 52.3 x 28.9 cm)
Unpacked: 19.8 lbs (9 Kg)
EMI standard
FCC Class B
Mounting
Standard VESA 4-hole 100 mm x 100 mm
EPA Energy Star
As an Energy Star Partner, Hewlett-Packard has determined that this product meets the Energy Star guidelines for energy efficiency.
