    Fix HP Printer issue on macOS
HP Designjet T1100 and T1120 MFP Series Products - User interface options
Press Setup tab/Options/General to reach the dialog shown below.User interface options
Units of measure
Setup tab/Options/General/Units of measure
With this option you can select millimeters, centimeters, or inches as your units of measurement.Units of measure dialogs
Color balance
Setup tab/Options/General/Color balance
This option tells your scanner software whether to display color values in Cyan, Magenta, and Yellow (CMY) or Red, Green, and Blue (RGB) when setting Type of Original options.
Paper lists show
Setup tab/Options/General/Paper lists show
This option tells the scanner software whether to display paper sizes (dimensions) or paper titles (such as E-0, A3) where possible.
Use quick select lists
Setup tab/Options/General/Use quick select lists
This option determines the behavior of your interface in relation to making settings for Type of original, Input size, Output size, Scale, Printer, Accounting, and Scanner. This option is set by default. The default dialog order is that you first access an east-to-use list dialog and from there you can choose a specific Setup dialog by pressing the tool button.
With Quick select lists un-selected, you reverse the above order: your interface first presents the specific Setup dialog and you must from there choose to view the List dialog with current predefined and standard values for the options.
Leave this option selected if you primarily use the scanner software with standard and customized pre defined option values. Make the option empty if you primarily need to make specific adjustments and settings for your different copy jobs and usually bypass the lists with predefined values.
You can see below the Input size button behavior with and without the Quick select lists option selected: Quick select lists ON (first) and OFF (second). The Tool button on the Input Size dialog will activate the Input Size Setup dialog, and the Input size button in the Input Size Setup dialog will activate the Input Size dialog.Input size dialogInput size setup dialog
Print settings
Setup tab/Options/General/Print settings
Checking this option tells the scanner software to print out an overview of all your settings together with the copy.
Enable reprint
Setup tab/Options/General/Enable reprint
On the Copy Settings dialog box is a Reprint button, which can be enabled or disabled here. If the Enable reprint option is selected, the Copy tab/ Settings/Reprint option button will reprint the last image printed. This is useful if you suddenly realize that you need more copies than you initially requested.
Paper series
Setup tab/Options/Genera/Paper series
You can determine which types of size presets you want to appear in the size presets list (size option dialogs) when you set the Input Size or Output Size. Pressing the Paper series option displays a list of paper series' (ANSI, ARCH.....) and you select (mark) all the paper series' you want included in your size option dialogs. Be sure to select the "Custom" series if you want to have your own custom made size presets displayed in the size dialogs along with the standard sizes.
