HP Compaq dc7800 Business PC Specifications
Product description
The HP Compaq dc7800 Business Desktop PC is designed for businesses that require best in class lifecycle management, solutions that keep you up and running securely, as well as specialized designs to fit your individual needs. Plus, you can rely on the engineering experience built in so you can make the right choice and spend more time concentrating on your business success.
Product Features
Feature
Form factor
Ultra-slim Desktop
Small Form Factor
Convertible Minitower
Intel® Q35 Express Chipset
Processors
Intel® Core™ 2 Quad processors1,2; Intel Core™ 2 Duo processors1,2 ; Intel Pentium® dual-core processors1,2; Intel Celeron® processors 2
Intel Quad Core processors not available on USDT.
Memory*
PC2-5300 (DDR2-667 MHz) and PC2-6400 (DDR2-800 MHz) Non-ECC SODIMM Memory
* Above 3 GB, all memory may not be available due to system resource requirements.
PC2-5300 (DDR2-667 MHz) and PC2-6400 (DDR2-800 MHz) Non-ECC DIMM Memory
Memory slots
2 SODIMM
4 DIMM
4 DIMM
Hard drive(s)*
80GB 1.5GB/s 5400rpm and 7200rpm; 160GB 1.5GB/s 7200rpm.
* For hard drives, GB = 1 billion bytes. Actual formatted capacity is less. Up to 8GB (for XP and XP Pro) and up to 12GB (for Vista) of system disk is reserved for recovery software
80GB and 160GB 3.0GB/s 7200rpm and 10,000rpm; 250GB 3.0GB/s 7200rpm and 10,000rpm; optional dual drive RAID.
Removable media
PATA CD-RW/DVD-ROM Combo Slim Drive, PATA DVD-ROM Slim Drive, PATA Slim SuperMulti LightScribe DVD Writer
1.44-MB Diskette Drive, SATA DVD-ROM, SATA 48x/32x Combo Drive, SATA DVD+/-RW (DL/DF) SuperMulti LightScribe Drive, 16-in-1 Media Card Reader (3.5" and 5.25" versions.
Expansion bays
Internal: (1) 3.5 inch External: (1) Slimline Drive Bay
Internal: (1) 3.5 inch External: (1) 5.25 inch and (1) 3.5 inch
Internal: (2) 3.5 inch External: (3) 5.25 inch and (1) 3.5 inch
N/A
1 low profile PCI, 2 low profile PCI Express x1, 1 low profile PCI Express x16 (standard), 2 full-height PCI slots (available via optional riser card)
3 full-height PCI, 2 full-height PCI Express x1, 1 full height PCI Express x16
Graphics
Integrated Intel Graphics Media Accelerator 3100
Communications
Intel® 82566DM Gigabit Network Connection
Rear I/O ports and connectors
6 USB 2.0, 2 PS/2, 1 RJ-45, 1 VGA and 1 DVI-D, audio in/out
6 USB 2.0, 1 standard serial port, 1 optional serial port, 1 parallel port, 2 PS/2, 1 RJ-45, 1 VGA, audio in/out
Front I/O ports and connectors
2 USB 2.0, headphone and microphone
Dimensions (h x w x d)
2.60" x 9.90" x 10.0"
3.95" x 13.3" x 14.9"
17.63" x 7.00” x 17.8"
Input Device
PS/2 or USB Standard keyboard, USB Smartcard Keyboard, PS/2 or USB 2-button optical scroll mouse.
Warranty and Services
3 years of Parts Labor Onsite; other HP Care Pack Services available see HP Care Pack Central
Software/OS
Feature
  • Genuine Windows® Vista Business 32
  • Genuine Windows Vista™ Business 64
  • Genuine Windows Vista Home Basic 32
  • FreeDOS
