    Fix HP Printer issue on macOS
Printer Specifications for the HP Photosmart C8150, C8180, C8183, and C8188 All-in-One Printers
Figure : HP Photosmart C8100 All-in-One Series
HP Photosmart C8100 All-in-One models
Product model
Part number
HP Photosmart C8150
L2527A
HP Photosmart C8180
L2523A, L2526A, L2526B, L2529A
HP Photosmart C8183
L2526C
HP Photosmart C8188
L2526D
System requirements
Windows
Minimum system requirements
Recommended system requirements
Intel Pentium II (or equivalent compatible processor) or later
Intel Pentium III or later processor
128 MB RAM
256 MB RAM
Available USB port
SVGA 1024 x 768 display resolution with 24-bit color
CD-ROM drive (4x)
Internet access
800 x 600 monitor with 16-bit or higher color depth
Sound card
Microsoft Internet Explorer 5.5 or later
Adobe Acrobat 4.0 or later
Macintosh
G3 processor or later
G4 processor or later
128 MB RAM
256 MB RAM for OS X
Available USB port
CD-ROM drive
Internet access
800 x 600 display resolution with 16-bit or higher color depth
Sound card
Connectivity
The following connectivity is supported by Microsoft Windows 2000 Professional, XP Home, XP Professional and Vista; Mac OS X 10.2 and later.
  • USB 2.0 Hi-speed (10 feet (3 meters) or less in length)
  • Ethernet
  • Wireless
  • Integrated Bluetooth
Reading and writing to a CD or DVD is possible only with a USB connection. With an Ethernet, Wireless, or Bluetooth connection, reading and writing to the CD or DVD are not available and are not supported.
Physical dimensions
Dimension
Measure
Height
21.6 cm (8.5 inches)
Width
44.8 cm (17.6 inches)
Depth
38.8 cm (15.3 inches)
11.3 kg (25 pounds)
Paper-handling specifications
Type
Paper Weight
Input tray*
Output tray†
Photo tray*
Plain paper
20 to 24 lb. (75 to 90 gsm)
Up to 100 (20 lb. paper)
50 (20 lb. paper)
n/a
Legal paper
50 (20 lb. paper)
n/a
Cards
110 lb. index max (200 gsm)
Up to 40
25
Up to 20
Envelopes
Up to 10
10
n/a
Transparency film
N/A
Up to 30
15 or fewer
n/a
Labels
N/A
Up to 30
25
n/a
4 x 6 inch (10 x 15 cm) Photo paper
145 lb. (236 gsm)
Up to 30
25
Up to 20
8.5 x 11 inch (216 x 279 mm) Photo paper
N/A
Up to 30
10
n/a
* Maximum capacity.
† Output tray capacity varies, depending on the type of paper and the amount of ink you are using. HP recommends emptying the output tray frequently.
Printing specifications
  • Up to 1200 x 1200 rendered dpi black when printing from a computer
  • Up to 4800 x 1200 optimized dpi color when printing from a computer and 1200-input dpi
  • Print speeds vary according to the complexity of the document
  • Panorama-size printing
  • Method: drop-on-demand thermal inkjet
  • Language: PCL3 GUI
  • Duty cycle: Up to 3000 printed pages per month
Copying specifications
  • Copy resolution up to 4800 x 4800
  • Digital image processing
  • Up to 50 copies from original (varies by model)
  • Zoom to 400%, fit to page (varies by model)
  • Copy speeds: black-and-white copies up to 32 copies per minute, color copies up to 31 copies per minute
Scanning specifications
  • Image editor included
  • Integrated OCR software automatically converts scanned text to editable text (if installed)
  • Twain-compliant interface
  • Resolution: 4800 x 4800 dpi optical; 19200 dpi enhanced (software)
  • Color: 96-bit color, 8-bit grayscale (256 levels of gray)
  • Maximum scan size from glass: 21.6 x 30.4 cm (8.5 x 12 inches)
Power specifications
  • Power consumption: 25 watts maximum (average printing)
  • Input voltage: AC 100 to 240 V ~ 600 mA 50–60 Hz
  • Output voltage: DC 32 V===375 mA, 16 V===500 mA
Use only with the power adapter supplied by HP.
Environmental specifications
Recommended operating conditions
Recommended operating temperature range: 15º to 32º C (59º to 90º F)
Maximum operating conditions
Allowable operating temperature range: 5º to 40º C (41º to 104º F)
Humidity: 20% to 80% RH non-condensing
Storage conditions
Non-operating (Storage) temperature range: –20º to 60º C (–4º to 140º F)
In the presence of high electromagnetic fields, it is possible the output from the HP All-in-One might be slightly distorted.
HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields.
Energy Star
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products.
ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information, go to www.energystar.gov.
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309 and EN 12281:2002.
Plastic parts over 25 grams are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of product life.
Regulatory specifications
The HP All-in-One meets product requirements from regulatory agencies in your country/region. For a complete listing of regulatory notices, see the on-screen Help.
Regulatory model identification number
For regulatory identification purposes, your product is assigned a Regulatory Model Number. The Regulatory Model Number for your product is SDGOB-0712. This regulatory number should not be confused with the marketing name (HP Photosmart C8100 All-in-One series, etc.) or product numbers (L2523A, etc.).
