    Looking for Site Help?
HP Officejet J3600 All-in-One Series - Testing the Fax Setup
You can test your fax setup to check the status of the device and to make sure it is set up properly for faxing. Perform this test after you have completed setting up the device for faxing. The test performs the following tasks:
  • Tests the fax hardware.
  • Verifies that the correct phone cord is connected to the device.
  • Checks that the phone cord is plugged into the correct port.
  • Checks for a dial tone.
  • Checks for an active phone line.
  • Tests the status of your phone line connection.
The HP All-in-One device prints a report with the results of the test. If the test fails, review the report for information about how to fix the problem and rerun the test.
Testing the fax setup
  1. Set up the device for faxing according to your particular home or office setup instructions.
  2. Make sure that the print cartridges are installed, and that full-size paper is loaded in the input tray before starting the test.
  3. On the control panel, press Setup.
  4. Select Tools, and then select Run Fax Test.
    The device displays the status of the test on the display and prints a report.
  5. Review the report.
    • If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify that the settings are correct.
      A blank or incorrect fax setting can cause faxing problems.
    • If the test fails, review the report for more information on how to fix any problems found.
  6. After the fax report is reviewed, press OK. If necessary, resolve any problems found and rerun the test.
Country: Flag Bulgaria
