HP Photosmart R847 Digital Camera - Product Specifications
Product models
Product model
Part number
HP photosmart R847 Digital Camera
L2485A
L2487A
Windows minimum and recommended system requirements
Minimum system requirements
Component
Requirements
Operating System Compatibility
Windows 2000, XP
Processor
Pentium II 400 MHz
Free Hard Disk Space
200 MB
RAM
128 MB
Color Display
SVGA monitor, 800 x 600, 36-bit color
Internet Explorer
Internet Explorer 5.01 or higher
Recommended system requirements
Component
Requirements
Windows 2000, XP
Processor
Pentium IV
400 MB
RAM
256 MB
Color Display
Internet Explorer
Macintosh minimum and recommended system requirements
Component
Requirements
Mac OS 10.3.9 and higher
Processor
Power PC G3
175 MB
RAM
128 MB
Color Display
Component
Requirements
Processor
Power PC G4 or better
400 MB
RAM
256 MB
Color Display
Environmental specifications
Maximum operating conditions: 0 to 40 degrees C (32 to 104 degrees F) at 15% to 85% relative humidity.
Storage conditions: -30 to 65 degrees C (-22 to 149 degrees F) at 15% to 90% relative humidity.
Physical dimensions
Feature
External body dimensions
Measurements with camera off and lens cover closed
(width, depth, height): 98 mm (3.86 inches) by 26.5 mm (1.04 inches) by 63.15 mm 2.49 inches)
146 grams (5.15 ounces) without battery
Power specifications
Typical power usage: 1800 mW (with Image Display on).
Power sources include:
  • One rechargeable HP Photosmart R07 Lithium Ion battery for HP Photosmart R-series cameras
  • Power adapter included with camera (5 Vdc, 1A, 5 W)
  • HP AC power adapter included with an optional HP Photosmart dock (5 Vdc, 2A, 10 W)
Main features
Feature
Resolution
Pictures:
  • 8.15MP (3298 by 2472) effective pixel count
  • 8.28MP (3336 by 2484) total pixel count
Video clips (QVGA):
  • VGA
    • 640 by 480 total pixel count
    • Best—24 frames/sec
    • Better—12 frames/sec
  • QVGA
    • 320 by 240 total pixel count
    • Good—24 frames/sec
Sensor
Diagonal 7.183 mm (1/2.5 inches, 4:3 format) CCD
Color depth
36 bit (12 bits by 3 colors).
36 bit images are transformed into an optimized 24 bit image and stored in the JPEG format. This transformation results in no discernible change to color or detail in the stored image, and allows the image to be read by computers.
Lens
Focal length:
  • Wide—6.5 mm
  • Telephoto—19.5 mm
  • 35 mm equivalent—39mm to 115mm
F-Number:
  • Wide—f/3.5 to f/7.4
  • Telephoto—f/4.2 to f/8.8
Viewfinder
None
Zoom
  • 3x optical zoom with 10 positions between wide and telephoto
  • 8x digital zoom
Focus
Focus settings: Auto (Default), Close-up Auto (Default):
  • Wide—500 mm (19.7 in) to infinity
  • Telephoto—600 mm (23.62 inches) to infinity
Close-up—Wide, 100 mm to 1 m (3.94 inches to 39.4 inches)
Shutter speed
1/2000 to 10 seconds
Built-in flash
Yes, 6-second typical recharge time (9-second maximum recharge time at power-on)
Flash working range
Zoom Position Wide—Maximum with ISO Speed set to Auto: x.x m (xx.x ft) at f/3.5
Zoom Position Telephoto—Maximum with ISO Speed set to Auto: x.x m (xx.x ft) at f/4.2
Image Display
7.57 cm (2.98 in) color LTPS TFT LCD with backlight; 230,400 pixels (960 by 240) total pixel count
Storage
  • 32MB internal flash memory, not all of which is available for storing images and video clips
  • Slot for memory card.
  • This camera supports standard, high speed, and high capacity Secure Digital (SD) memory cards, 32MB to 8GB.
  • This camera supports storing a maximum of 1999 images on a memory card.
  • The number of images or video clips that can be saved in memory depends on the Image Quality and Image Quality settings Video Qualitysettings
Compression format
JPEG (EXIF) for pictures
Motion JPEG for video clips
Interfaces
Dock connector (HP 1253–7135) and USB cable connector (USB 2.0 Full Speed/USB mini-B) connected to either:
  • Power adapter (via USB connector on the side of the camera)
  • Optional HP Photosmart dock (via dock connector on the bottom of the camera)
Standards
  • USB—PTP and MSDC
  • JPEG
  • Motion JPEG
  • DPOF
  • EXIF
  • DCF
  • DPS
Temperature range
Operational:
0° to 50° C (32° to 122° F) at 15% to 85% relative humidity
Storage:
–30° to 65° C (–22° to 149° F) at 15% to 90% relative humidity
