HP Photosmart A320 and A321 Printers - Blinking Lights
Lights blinking, or flashing, on the printer can signal a possible issue with the printer. This document lists steps to correct any issues indicated by the flashing lights. Find the pattern of flashing lights that match the lights flashing on your printer and follow the directions in the table below.
Flashing lights can be caused by multiple issues, so there may be multiple solutions listed in each section below.
On light
Red Eye light
Resume light
Print Cartridge light
Attention light
PictBridge light
Off
Off
Off
Off
Off
Off
Figure : All lights are off
Issue
The HP Photosmart printer is not responding.
Solution
  1. Check the On light located on the top of the HP Photosmart printer. If it is not lit, the HP Photosmart printer is turned off.
  2. Make sure the power cord is firmly connected to the HP Photosmart printer and plugged into a power outlet.
  3. Press the On button to turn on the HP Photosmart printer.
Cause
The HP Photosmart printer is turned off.
On light
Red Eye light
Resume light
Attention light
PictBridge light
On
Off
Off
Off
Off
Off
Figure : On light is solid green
Issue
On light is solid green.
Solution
The printer is on and ready to print.
No action required.
On light
Red Eye light
Resume light
Attention light
PictBridge light
Blinking
Off
Off
Off
Off
Off
Figure : On light is blinking
Issue
The on light is blinking.
Solution
The printer is starting up or busy.
No action required.
On light
Red Eye light
Resume light
Attention light
PictBridge light
On
On
Off
Off
Off
Off
Figure : Red-eye light is solid green
Issue
The red-eye light is on.
Solution
Automatic photo correction feature is turned on.
No action required.
On light
Red Eye light
Resume light
Attention light
PictBridge light
On
Off
Blinking
Off
Off
Off
Figure : Resume light is blinking
Issue
The printer is out of paper.
Solution
To load paper follow the steps below.
  1. Open the output tray on the front of the printer. The input tray opens automatically.
    Figure : Inserting paper in the input tray
  2. Place a few sheets of HP Advanced Photo Paper in the input tray with the glossy side facing the front of the printer. A paper sample pack is included in the box with the printer.
  3. Align the paper against the left side of the input tray. Adjust the paper-width guide to fit close to the right edge of the paper without bending it.
The resume light blinking indicates that the OK button should be pressed to resume printing after the error is cleared.
On light
Red Eye light
Resume light
Attention light
PictBridge light
On
Off
Off
On
Off
Off
Figure : Print Cartridge light is solid red
Issue
The print cartridge is low on ink.
Solution
Replace the print cartridges. To replace the cartridges follow the steps below.
  1. Open the print cartridge package.
  2. Push down and pull the print cartridge toward you out of its slot.
  3. Remove the new print cartridge from its packaging.
  4. Pull the pink pull- tab to remove the clear tape from the print cartridge.
    Figure : Removing the tape from the print cartridge
    Do not touch or remove the ink nozzles or the copper- colored contacts.
  5. Open the print cartridge door.
    Figure : Opening print cartridge door
  6. Insert the print cartridge into the print cartridge cradle with the label facing up and the copper- colored contacts facing the inside of the printer.
  7. Push the print cartridge into the cradle until it snaps into place.
  8. Close the print cartridge door.
  9. The printer aligns the print cartridge, ensuring high print quality. An alignment page prints.
On light
Red Eye light
Resume light
Attention light
PictBridge light
On
Off
Off
Blinking
Off
Off
Figure : Print Cartridge light is blinking
Issue
Print Cartridge light is blinking red.
Solution
This indicates that the print cartridge door is open. Close the print cartridge door and resume printing.
On light
Red Eye light
Resume light
Attention light
PictBridge light
On
Off
Off
Off
Blinking
Off
Figure : Attention light is blinking
Issue
The attention light blinks red indicating that a paper jam has occured.
Solution
  1. If the paper came part way through the front of the printer, gently pull the paper towards you to remove it.
  2. If the paper did not come part way through the front of the printer, try removing it from the back of the printer by following the steps below.
    1. Remove the paper from the input tray.
    2. Gently pull the jammed paper to remove it from the back of the printer.
  3. If you cannot grasp the edge of the jammed paper to remove it, try the following:
    1. Turn off the printer.
    2. Unplug the printer power cord from the electrical outlet.
    3. Wait about 10 seconds, and then plug the power cord back in.
    4. Turn on the printer. The printer checks for paper in the paper path and will automatically eject the jammed paper.
    5. Press OK to continue.
Cause
On light
Red Eye light
Resume light
Attention light
PictBridge light
On
Off
Off
Off
Off
On
Figure : PictBridge light is solid green
Issue
The PictBridge light is solid green.
Solution
A PictBridge camera is connected to the printer, and the printer is ready to print.
No action required.
On light
Red Eye light
Resume light
Attention light
PictBridge light
On
Off
Off
Off
Off
Blinking
Figure : PictBridge light is blinking
Issue
PictBridge light is blinking green.
Solution
The printer is printing a photo from your camera.
Do not disconnect your camera if the light is flashing green.
No action required.
