    Fix HP Printer issue on macOS
HP iPAQ 500 Voice Messenger Series - Using Wireless Manager
Using Wireless Manager, you can easily turn on/off the functions of Wi-Fi connection, Bluetooth connection, and Phone features.
To use wireless manager, pressStart > Settings > Connections > Wireless Manager.
Flight Mode
Flight mode is a condition when all wireless connections on your iPAQ are turned off.
To turn all wireless connections on/off at the same time:
  1. To use wireless manager, press Start > Settings > Connections > Wireless Manager.
    On the Home screen, scroll and select Wi-Fi to open the Wireless Manager.
  2. Select All and press Action button to turn all wireless connections on/ off.
Quick Launch
Quick Launch is a simple way for you to open the Quick List that lets you turn off your iPAQ, manage wireless connections, change profiles, or lock your keypad.
To access the Quick List:
  1. Press and hold the Home key to access the Quick List.
  2. Scroll to select from the list.
