HP Compaq 8510w Mobile Workstation Product Specifications
Product description
The HP Compaq 8510w Mobile Workstation gives you exceptional computational and visualization performance in a powerful yet portable 15.4-inch diagonal wide screen notebook weighing just 6.1 lbs/2.77 kg and as thin as 1.1 in/28 mm.
Product features
Feature
Specification
Processor
Intel Core 2 Duo (up to 2.4-GHz, 4-MB L2 cache), Intel Core 2 Duo (1.8-GHz, 2-MB L2 cache)
Mobile Intel PM965
ISV Certifications
MCAD
AutoDesk AutoCAD
AutoDesk Inventor
AutoDesk Revit
Bentley Microstation
Dassault Catia V5
UGS I-DEAS NX 10
UGS I-DEAS NX 11
UGS/PLM Unigraphics NX, NX2, NX3
UGS Solidedge
PTC Pro/E 2001 Mechanica
PTC Pro/E Wildfire Mechanica
MSC.Patran
SensAble
Solidworks
CoCreate OneSpace Designer
ICEM Surf
PTC DV Mockup
DCC
Discreet 3DS MAX/Combustion
Adobe Premiere/After Effects
Alias Maya
Alias Studio Tools
Avid SoftImage XSI/3D
Avid Xpress Pro
GIS
ESRI ArcGIS 9
Oil & Gas
SMT, Landmark/GeoGrpahix, EDS, Roxar, Schlumberger/Petrel
Memory
DDR2 SDRAM, 667-MHz, two slots supporting dual channel memory, 512/1024/2048-MB SODIMMs, up to 4096-MB total.
Hard drive(s)
SATA 80/120/160-GB 5400 rpm, 80/100-GB 7200 rpm, HP 3D DriveGuard
Removable media
12.7-mm optical drives: Blu-ray Disc DVD+/-RW SuperMulti DL, DVD+/–RW SuperMulti DL LightScribe, DVD+/–RW SuperMulti DL, DVD/CD-RW Combo, DVD-ROM
15.4-inch diagonal WXGA (1280 x 800 and 16M colors), WSXGA+ WVA (1680 x 1050 and 16M colors), WUXGA WVA (1920 x 1200 and 16M colors)
Graphics
NVIDIA Quadro FX 570M, 256MB (512MB TurboCache), ATI Mobility FireGL V5600, 256 MB (512 MB HyperMemory)
Audio
High Definition Audio, stereo speakers, stereo headphone/line out, stereo microphone in, integrated microphone
Wireless support
Optional HP ev2200 1xEV-DO and optional HP hs2300 HSDPA Broadband Wireless Module); Intel and Broadcom 802.11a/b/g draft-n, a/b/g, b/g, Bluetooth 2.0, HP Wireless Assistant
Communications
Intel Gigabit Network Connection (10/100/1000 NIC), 56K v.92 modem
1 Type I/II PC Card slot supports 32-bit CardBus and 16-bit cards, Secure Digital slot
Ports and connectors
4 USB 2.0 ports, VGA, HDMI,10 stereo microphone in, stereo headphone/line out, 1394a, power connector, RJ-11/modem, RJ-45/ethernet, docking connector, secondary battery connector
Input device
Full-sized keyboard, enhanced dual pointing devices (touchpad with scroll zone and pointstick)
Manageability
Intel Centrino Pro processor technology capable, HP Backup and Recovery Manager, HP Client Manager Software, HP OpenView Radia Management Agent, HP Client Management Interface, HP Performance Tuning Framework
Security
HP ProtectTools, TPM Embedded Security Chip 1.2, HP Fingerprint Sensor, Symantec Norton Internet Security, integrated Smart Card Reader, Sold separately: Kensington lock, HP Privacy Filter
Dimensions
(h × w × d)
1.1 in (at front) x 14.0 in x 10.24 in / 27.5 mm (at front) x 357 mm x 260 mm
Starting at weight: 6.1 lbs/2.77 kg (weight will vary by configuration)
Power
8-cell (73 WHr) Lithium-Ion battery, optional HP (52 WHr) Extended Life Battery, optional HP (95 WHr) Ultra-Capacity Battery, 90W HP Smart AC Adapter, HP Fast Charge
Expansion solutions
HP 3-in-1 NAS Docking Station, HP Advanced Docking Station, HP Docking Station, External MultiBay II, HP Monitor Stand, HP Adjustable Notebook Stand
Limited 3-3-3 or 3-3-0 warranty options available, depending on country; 1-year limited warranty on primary battery
Software/OS
Feature
Preinstalled:
  • Genuine Windows Vista Business 32/64
  • Genuine Windows Vista Home Basic
  • Genuine Windows XP Professional
  • FreeDOS
Supported:
  • Genuine Windows Vista Enterprise
  • Genuine Windows 2000
Certified:
SuSe Linux Enterprise Desktop 10
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
