HP 910 Series Printers - Replacing the Print Cartridges
Perform the following steps to replace the print cartridges
Replace the print cartridges
  1. Press the Power button () to turn on the printer.
  2. Open the printer cover. The print cartridge cradle moves to the center of the printer.
  3. Push down on the print cartridge.
  4. Slide the print cartridge out of the cradle.
      Figure : HP 910 Series Printers - Sliding the print cartridge out of the cradle
  5. Remove the replacement print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strip is on the bottom and facing the printer.
      Figure : HP 910 Series Printers - Removing the plastic tape
    1. Remove plastic tape
    Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
      Figure : HP 910 Series Printers - Ink Nozzles and Copper contacts
    1. Ink nozzles
    2. Copper contacts
  6. Slide the print cartridge firmly into the cradle at a slight upward angle.
    Figure : HP 910 Series Printers - Sliding the print cartridge into the cradle
  7. Push the cartridge firmly into the cradle to hear a snap.
  8. Close the printer cover.
