Adding or Replacing a Hard Drive in Compaq Presario SR5000 Series PCs
This document pertains only to HP desktop computers with the following computer case:
HP and Compaq desktop  computer
Before you begin
  • Turn off the computer, disconnect all cables, and transfer the computer to a clear, flat, stable work surface over a non-carpeted floor.
  • To add an additional SATA hard disk drive, an additional SATA data cable is required.
  warning:
If you are adding an additional hard drive
When adding a hard drive, it is important to identify the connectors on the motherboard.
The hard drive connectors on the motherboard must match the type of hard drive you wish to connect. If your motherboard has SATA data connectors and one is not in use, you can attach an additional SATA hard drive. If your motherboard has an IDE connector available, you can attach an IDE hard drive.
If you want to install an IDE hard drive to a motherboard that has only SATA data connectors, a third-party adapter is necessary.
    Figure : Motherboard with IDE and SATA data connectors
    Motherboard with SATA and IDE connectors
  1. IDE connectors
  2. SATA data connectors
    Figure : Example of SATA connections
    Hard drives with SATA cables connected
  1. Power cable
  2. SATA data cable
    Figure : Example of an IDE connection
    Hard drive with IDE cables connected
  1. IDE ribbon cable
  2. Power cable
Video overview
View the following video before using the steps in this document.
Find which steps to use
If you would like to add a second hard drive of the same type or replace the existing primary or secondary hard drive, use the section Removing or replacing a drive from the drive cage.
If you would like to replace the pocket media drive bay with a 3rd hard drive (or a replacement pocket media drive bay), use the section Replacing the pocket media drive bay with another drive.
If your computer does not have a drive cage, or pocket media drive bay and you would like to add a 3rd hard drive or pocket media drive bay, use the section Installing a drive into the upper drive bay (not the lower drive cage).
Use the steps in this section to remove a hard drive so that an empty bay can be used to install a new drive.
  warning:
Step 1
With all cables disconnected from the computer, remove the right side panel and the front cover.
If you need assistance, refer to the HP support documents Opening the PC Case and Removing the Front Cover.
Removing the right side panel
The hard drive or drives are mounted in a removable cage.
The removable hard drive cage
Step 2
Detach the two screws that secure the hard drive cage to the computer.
Two screw securing the hard drive cage to the computer
Step 3
Push down and hold the latch on the side of the cage.
Pushing the latch on the side of the hard drive cage
Step 4
Slide the cage upward.
Sliding the cage upward
Step 5
Lift the cage out of the computer.
If you are adding a second additional drive, skip to the next section Installing another drive into the cage.
Lifting the cage out of the computer
Step 6
Remove the power and data cables from the back of the hard drive.
Power and data cables connected to the hard drive
Your hard drive has either parallel or serial ATA power and data connectors. Serial ATA power and data connectors each have a latch that must be squeezed to remove the connector.
Latches on the power and data cables
Step 7
Remove the four screws, two on each side, that secure the hard drive to the cage.
Screws securing the hard drive to the cage
Step 8
Slide the hard drive out of the top of the drive cage.
Go to the next set section to install a drive into the drive cage.
Sliding the hard drive out of the cage
Use the steps in this section to install a new hard drive.
Step 1
Determine if you are installing a new parallel ATA hard drive. If so, make sure the drive is set to CS (cable select).
Parallel ATA hard drive
Step 2
Slide the drive into the cage...
Sliding the drive into the cage
...until it is all the way in.
Hard drive all the way into the cage
Step 3
Make sure the hard drive and cage screw holes align.
Screw holes in the hard drive and the cage aligned
Step 4
Check that the connectors are at the top of the cage.
Drives in the cage
Step 5
Attach the four screws.
Screws that secure the hard drive in the cage
Step 6
Attach the power and data connectors to the back of the drive...
Power and data cables attached to the hard drive
...If the drive uses a flat ribbon cable (PATA) and only one drive is installed, attach it to the flat ribbon connector labeled Master. If two PATA drives exist, the second should attach to the middle connector on the flat ribbon cable labeled Slave.
Once the hard drive cage is reinstalled in the computer, the third connector connects to the motherboard.
Ribbon cable labeled Master and Slave
Step 7
To replace the hard drive cage, align the four tabs on the side of the cage...
Four tabs on the side of the cage
...with the four slots inside the computer.
Four slots on the computer
Step 8
Slide the cage down until it snaps into place.
Sliding the cage down to snap into place
Step 9
Reattach the two drive cage screws.
Drive cage screws
Step 10
Replace the side panels and the front panel, and then reconnect the cables and power cord.
MBR or NTFS partitions are limited to 2 TB (without using dynamic disks and volume sets). If you are installing a hard drive that is 2 TB or greater, HP recommends formatting the drive using GPT partitions.
Refer to the HP support document Opening the PC Case.
Replacing the side panel
To replace the pocket media drive bay with a 3rd hard drive (or another pocket media drive bay), use the following steps to remove the external drive bay located just below the CD/DVD drive bays on the front of the computer.
Step 1
Remove any media in the drive bay, and then remove the side panel and the front panel from the computer.
Removing the front panel
Step 2
Squeeze tightly on the sides of the USB connector on the back of the drive bay and detach the connector.
Detaching the connector from the drive
Step 3
Remove the two screws on the side of the drive bay.
Screws on the side of the drive bay
Step 4
Pull the drive bay out of the computer.
Go to the next set section to install a hard disk drive into the empty bay.
Pulling the drive bay out of the computer
Follow these steps to install a new pocket media drive or a hard disk drive into the 3.5-inch bay on front of your computer. These steps are easier if you remove the adjacent CD/DVD drive first.
Step 1
If the drive has not been used before, remove the break-away EMF shield from the front of the bay.
Break-away EMF shield
Step 2
Pry the shield with a flat-headed screwdriver...
Prying the shield with a screwdriver
...until it breaks away.
The shield breaking away
Step 3
Push the drive into the bay all the way through the front of the computer.
Pushing the drive bay into the computer
Step 4
If installing an HP Pocket Media drive, be sure the screw holes on the drive bay align with the screw holes on the computer marked PMD 2.
Or...
Screw holes aligning
...if installing a hard disk drive, ensure the screw holes on the hard disk drive bay align with the screw holes in the computer marked HDD.
Step 5
Install the screws.
Installing screws
Step 6
Depending on the hard drive type, connect serial ATA or parallel ATA power and data cables to the drive and to the motherboard.
If you are installing a pocket media drive bay, connect the USB cable to the USB riser on the motherboard.
Serial and parallel power cables
USB connectors
Step 7
Replacing the front panel
