    Fix Windows 10 Update Issues
HP CM8060/CM8050 Color MFP with Edgeline Technology - Clean the device
The device does not need to be cleaned often. However, if dirt is visible on the flatbed glass or on the white-vinyl backing, or if streaks or spots appear in copies, clean the flatbed glass and the white-vinyl backing. Clean the outside of the device and the touchscreen periodically to avoid getting dirt on the flatbed glass and the white-vinyl backing.
Use the following information to clean the device.
Figure : clean the device
Clean the outside of the device with a soft, lint-free cloth dampened with water, or with water and a mild detergent.
Clean the touchscreen
Figure : clean the touchscreen
Clean the touchscreen by gently wiping it with a lint-free cloth dampened with water. Do not pour or spray water directly onto the touchscreen. Do not use any other liquid. Solvents and cleaners can damage the touchscreen.
Clean the flatbed glass
Figure : clean the flatbed glass
Clean the flatbed glass only if dirt is visible or if streaks or spots appear in copies.
Gently wipe the glass with a lint-free cloth dampened with water. If water does not work, use a cloth dampened with isopropyl alcohol. Do not pour or spray the cleaner directly onto the glass. Do not press hard on the glass.
Clean the glass scanner strip
Figure : clean the glass scanner strip
The small glass strip that is to the left of the flatbed glass has a special coating. Use only gentle pressure when cleaning this glass strip. Wipe the glass scanner strip with a clean, dry lint-free cloth. Only if necessary, use a slightly water-dampened lint-free cloth to clean the glass strip.
Never pour or spray liquids directly onto the glass scanner strip. Only use gentle pressure when cleaning the glass scanner strip.
Clean the white-vinyl backing
Figure : clean the white-vinyl backing
Clean the white-vinyl backing that is under the flatbed cover only if dirt is visible or if spots appear in copies.
Gently wipe the backing with a lint-free cloth dampened with water. If water does not work, use a cloth dampened with isopropyl alcohol. Do not pour or spray the cleaner directly onto the backing.
