    Fix Windows 10 Update Issues
HP CM8060/CM8050 Color MFP with Edgeline Technology - Replace staple cartridges
The HP Multifunction Finisher is an optional accessory. Other finishers do not have staplers.
A message appears on the control panel whenever a staple cartridge needs to be replaced. The optional HP Multifunction Finisher has two staplers. Stapler 1 is on the right, closest to the device. Stapler 2 is to the left and above Stapler 1. The control-panel message indicates which stapler is empty.
To avoid injury, do not reach into the device to change the staple cartridge while the device is operating.
  1. Open the stapler door.
    Figure : stapler doors open
  2. To remove the staple cassette, pull forward on the green lever that is on the front of the staple cassette, and then pull the staple cassette straight out.
    Figure : remove the staple cassettes
  3. To remove the staple cartridge from the cassette, push in at the arrow on each side and then pull up to release the cartridge.
    Figure : remove staple cartridge
  4. Insert the new staple cartridge into the staple cassette. Push the cartridge straight down until it snaps into place.
    Figure : install staple cartridge
  5. Push the staple cassette straight into the slot.
    Figure : install staple cassette
  6. Rotate the green lever up until it snaps into place.
    Figure : lock staple cassete
  7. Close the stapler door.
