    Fix Windows 10 Update Issues
HP CM8060/CM8050 Color MFP with Edgeline Technology - Replace ink cartridges
The device uses four color ink cartridges and one bonding agent cartridge. The bonding agent adheres the ink to the paper and improves the durability of the printed output.
A message appears on the control panel whenever a cartridge needs to be replaced. The control-panel message tells you which cartridge needs to be replaced.
An ink cartridge expires twelve months after the date of installation if it is installed prior to the install-by date shown on the ink cartridge package. If it is installed after the install-by date, the ink cartridge will expire in less than twelve months.
Figure : ink cartridge location
The bottom of each cartridge has a unique shape so it fits only into its corresponding slot.
  1. Open the ink-cartridge door.
    Figure : ink-cartridge door open
  2. Push the cartridge back and then up to release it, then pull the cartridge straight out.
    Figure : remove the ink cartridges
  3. Push the new cartridge straight in until it locks into place.
    Figure : ink-cartridge door closed
  4. Please return your genuine HP supplies for recycling to Hewlett-Packard. For more information, please visit us at www.hp.com/go/recycle.
    On the Supplies Status Page, the HP logo only appears in front of the supply name when genuine HP supplies are used.
