    Fix Windows 10 Update Issues
HP CM8060/CM8050 Color MFP with Edgeline Technology - Order supplies and accessories
The device alerts you when the supply items are getting low. Use the information in this section to order replacement ink cartridges and staple cartridges. To order supplies, use the embedded Web server. Click the Product Support link.
Some maintenance agreements include supplies.
Supplies
Item
HP part number
Black ink cartridge
C8750A
Cyan ink cartridge
C8751A
Magenta ink cartridge
C8752A
Yellow ink cartridge
C8753A
Bonding agent ink cartridge
C8754A
Multiple staple cartridge pack (contains three cartridges)
C5967A
The following accessories are available for the device. To add accessories, contact the HP service and support person.
Accessories
Item
HP part number
HP Multifunction Finisher
C5959A
HP 4-Bin Job Separator
C5964A
HP High Capacity Input Tray (Tray 5)
C5961A
Standard Output Bin
C5963A
HP Analog Fax Accessory
C5954A
HP Parallel EIO interface
J7972G
HP Jetdirect 635n IPv6/IPsec print server
J7961G
Windows software CD
C5956-61104
Macintosh software CD
C5956-61105
System Administrator's CD
C5956-61106
