HP Designjet Z3100ps Photo Printer Series - Select print quality
The printer has various print-quality options because best-quality printing requires some loss of speed, while fast printing implies some reduction in print quality.
Therefore, the standard print-quality selector is a slider that allows you to choose between quality and speed.
Alternatively, you can select from the custom options: Best, Normal, and Fast. There are also three supplementary custom options that may have an effect on print quality: Maximum detail, More passes, and Gloss enhancer.
In the Microsoft Windows driver dialog, the rendering resolution for your job is displayed in the Custom Print Quality Options dialog box. In the Macintosh OS Print dialog, it is displayed in the Summary panel.
You can select print-quality options in the following ways:
  • In the Microsoft Windows driver dialog: Go to the Paper/Quality tab and look at the Print Quality section. If you select Standard Options, you will see a simple slider with which you can select speed or quality. If you select Custom Options, you will see the more specific options described above.
  • In the Macintosh OS Print dialog (PostScript driver): Go to the Image Quality panel. If you select Standard quality options, you will see a simple slider with which you can select speed or quality. If you select Custom quality options, you will see the more specific options described above.
  • In the Macintosh OS Print dialog (PCL driver): Go to the Paper Type/Quality panel and select Paper. If you select Standard quality options, you will see a simple slider with which you can select speed or quality. If you select Custom quality options, you will see the more specific options described above.
  • On the Embedded Web Server's Submit Job page: Select Basic settings, Print quality. If you then select Standard options, you can choose between Speed and Quality. If you select Custom options, you will see the more specific options described above.
  • Using the front panel: Select the (Setup menu) icon, then Printing preferences, Print quality.
    If you have set the print quality from your computer, that overrides the print-quality setting in the front panel.
You can not change the print quality of pages that the printer is already receiving or has already received (even if they have not started to print yet).
