HP CM8060/CM8050 Color MFP with Edgeline Technology - Receive faxes
The device can receive incoming faxes if an analog fax accessory is installed. If this accessory is not installed, you can use a LAN fax service or Internet fax service to send faxes, but the device cannot receive faxes.
The device places incoming faxes into the active job queue. If no other jobs are in the queue, the device prints the fax immediately. If other jobs are in the queue, the device prints the fax after the jobs that are ahead of it in the queue. If you want to print the fax sooner, you can promote it in the job queue.
If the system administrator has set up a schedule for printing faxes, it is possible that all faxes are stored on the device and then printed at a later time.
Promote a fax in the job queue
  1. From the Home screen, touch Job Status.
  2. On the Active tab, open the drop-down list named Select Job Type, and select Copy, Print, Incoming Fax Jobs.
  3. From the list of jobs, select the job, and then touch Promote. The device moves the job as far forward as possible in the job queue.
Country: Flag Bulgaria
