    Looking for Site Help?
HP Designjet Z3100ps Photo Printer Series - Feed and cut the paper
To feed and cut the paper when the automatic cutter has been disabled, press the Form feed and cut key on the front panel. The paper advances and the printer makes a straight cut on the front edge.
The printer may not cut the paper directly after the Form feed and cut key is pressed, as each time a print is printed the printheads are serviced and the paper cannot be cut until the process completes.
Remove the cut piece from the output tray.
Figure : Unload paper
If strips or short prints are left in the output tray the printer could jam.
Photo and coated paper requires careful handling.
Country: Flag Bulgaria
