    Fix HP Printer issue on macOS
HP CM8060/CM8050 Color MFP with Edgeline Technology - Menu structure
This table shows the overall menu structure.
Use the Supplies Status feature to configure the paper size and type for each tray. You cannot use the Administration menu to configure the trays.
Menu structure
Menu
Sub-menu
Details
See Information menu.
Default Job Options
To configure default settings for the E-mail and Network Folder features, use the embedded Web server. See Advanced e-mail setup and Network folder setup.
Default Copy Options
See Default Copy Options.
Default Fax Options
See Default Fax Options.
Default Print Options
See Default Print Options.
Time/Scheduling
See Time/Scheduling menu.
Management
See Management menu.
Initial Setup
Networking and I/O
See Networking and I/O menu.
Fax Setup
See Fax Setup menu.
E-mail Setup
See E-mail Setup menu.
Device Behavior
See Device Behavior menu.
Troubleshooting
See Troubleshooting menu.
Resets
See Resets menu.
