    Fix HP Printer issue on macOS
HP CM8060/CM8050 Color MFP with Edgeline Technology - Navigate the administration menu
From the Home screen, touch Administration to open the menu structure. You might need to scroll to the bottom of the Home screen to see this feature.
The Administration menu has several sub-menus, which are listed on the left side of the screen. Touch the name of a menu to expand the structure. A plus sign (+) next to a menu name means that it contains sub-menus. Continue opening the structure until you reach the option that you want to configure.
A breadcrumb trail at the top of the screen indicates which menus have been opened. To return to a higher level in the menus, touch one of the underlined links. To return to the previous level, touch Back.
To exit the Administration menu, touch the Home button () in the upper-left corner of the screen.
The device has built-in help that explains each of the features that are available through the menus. To open the Help system, touch the Help button () in the upper-right corner of the screen. The help provides the details about each screen.
The tables in the sections that follow indicate the overall structure of each menu.
