    Windows 11 Upgrade Guide
HP iPAQ h6340 Pocket PC - How to Add a Pass Key in the Phone
Issue:
A pause can be programmed any time when user is speed dialing an automated service where listen to a message and then enter another number.
Examples would be using a calling card or a voice mailbox with multiple extensions, or a IVR.
Solution
  1. Enter the main phone number
  2. When reaching the place where user want to add the pause, press the P key
  3. Enter the digits wanted to have your phone dial after the pause
If this does not work Please try the alternate step:
  1. Create the Contact which you need to dial in the given example format
    Eg:- 18002616430 P 12345 P 726226
  2. After creating the Contact, dial using the it
Pause key may varies from service provider to service providers & phone to phone.
