Deskjet 9800 - Series A3 Border less Printing Issue with Acrobat Reader
Issue:
When printing A3 Border less from Acrobat reader to Deskjet 9800 printer, it may cut off the image on either of the edges.
Solution
Workaround:
  1. From Acrobat Reader click on File->Print
  2. Click on HP Deskjet 9800 Series properties and select the following Paper/Quality tab configuration:
  3. Click on Advanced tab and change the Overspray value to least.
  4. Click Ok to go back to Acrobat Reader and select the following print setting:
  5. Click on Advanced and select Print as Image, then click OK and click OK to start printing.
