    Fix Windows 10 Update Issues
HP Officejet Pro L7500, L7600, and L7700 Series All-in-One - Description of the External Parts of the All-in-One
Use the images and tables below to identify the components and external parts of the HP L7500, L7600 and L7700 series All-in-One.
Front and top of the HP Officejet Pro L7500, L7600 and L7700 Series All-in-One
Figure : Front and top view of the HP Officejet L7500, L7600 and L7700 Series All-in-One
Number
Component
1
Automatic document feeder
2
Scanner glass
3
Control panel
4
5
Output tray
6
Output tray extension
7
Length/width guides
8
Tray 1
9
Tray 2 (available with some models)
10
Front Universal Serial Bus (USB) port for a camera or other storage device
11
Memory card slots
12
Memory device light
13
Document feeder tray
14
Width guides
Control panel overview
Figure : Control panel showing both, the two-line display and the color display options (varies by model)
Number
Component
1
Speed Dial
Select a speed dial number.
2
Scan
Select a scan destination.
3
Fax
Open the menu for the fax function.
4
keypad
Enter fax numbers, values, or text.
5
Two-line or color Display
(varies by model)
Shows status and error messages, mode and setup menus and their options, help information, and ink cartridge levels.
6
Setup
Access the menu system for reports, settings, and maintenance.
7
Copy
Open the menu for the copy function.
8
Open the menu for the photo function.
9
Power button and lights
Turn the device on or off.
