    Fix Windows 10 Update Issues
HP Inkjet Supplies - HP 74XL Black Inkjet Print Cartridge Specifications
The high-capacity HP 74XL Black Inkjet Print Cartridge produces fast, laser-quality black text for frequent printing of documents and graphics.
Illustration
Use
High-performance, moderate black printing
Ink volume
18 ml
Part number
CB336W
This genuine HP inkjet print cartridge provides proactive alerts so you will always know when ink levels are running low, and it can be recycled conveniently through the HP Planet Partners program.
For information on cartridge page and photo yields see www.hp.com/go/pageyield.
Operating temperature
Ideal: room temperature (no extremes)
Min: 15 degrees Celsius Max: 35 degrees Celsius
Min: 59 degrees Fahrenheit Max: 95 degrees Fahrenheit
Storage temperature
Min: -15 degrees Celsius Max: 35 degrees Celsius
Min: 5 degrees Fahrenheit Max: 95 degrees Fahrenheit
Install-before date
Be sure to install and begin using the HP inkjet print cartridge before the install-before date on the cartridge package.
Altitude restrictions
Target: 8,000 feet
Max: 17,000 feet
HP inkjet print cartridges are not designed to be transported in printers at high altitudes, such as on airplanes.
