HP Officejet J5700 All-in-One Printer Series- Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Attach the control panel overlay, if not attached
  • Attach the trays and load paper
  • Connect the power cord and adapter
  • Turn the All-in-One on
  • Set the language and country/region
  • Install the cartridges
  • Align the cartridges
  • Set the date and time
  • Connect the supplied phone cord
Follow these steps in order.
  1. Remove all tape and packing material on the outside and inside of the product.
    Figure : Remove all packing materials
    Remove tape and packing materials
  2. Remove the orange shipping lock from the inside of the product.
    Figure : Remove shipping lock
Step three: Attach the control panel faceplate, if not attached
If the control panel faceplate is not already attached, do the following:
  1. Align the faceplate over the buttons on the top of the product.
    Figure : Align the faceplate
  2. Snap the faceplate firmly into place.
Step four: Attach the trays and load paper
  1. Insert the tabs of the bottom tray into the product, and then lower the tray until it is flat.
  2. Slide the paper adjuster over to the left.
  3. Insert plain white paper.
  4. Attach the top (output) tray. Hook the top edge of the tray into the light gray latches, and then lower it.
  5. Flip open the paper tray extender.
Step five: Connect the power cord and adapter
  1. Plug the printer end of the power adapter into the back of the printer.
  2. Plug the adapter end of the power cord into the power adapter.
  3. Plug the remaining end of the power cord into a grounded wall outlet or surge protector.
Figure : Connect the power cord and adapter
Step six: Turn the All-in-One one
On the product control panel, press the On button ().
The green light flashes, and then becomes solid.
Step seven: Set the language and country/region
If the display screen prompts you to select a language, follow these steps.
  1. Use the Arrow keys () to scroll through the languages. When the language you want to use appears, press OK.
  2. When prompted to confirm, press 1 for Yes, or 2 for No.
  3. Use the Arrow keys () to scroll through the countries/regions. When the country/region you want to use appears, press OK.
  4. When prompted to confirm, press 1 for Yes, or 2 for No.
Step eight: Install the cartridges
  1. Raise the top cover of the product.
    Figure : Raise the cover
  2. Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
      Figure : Remove the tape
    1. Copper-colored contacts
    2. Plastic tape with pink pull tab (must be removed before installing)
    3. Ink nozzles under tape
    Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
  3. Slide the new cartridge forward into the empty slot. Then gently push the upper part of the cartridge forward until it clicks into place.
    • Slide the tri-color cartridge into the left slot.
    • Slide the black or photo cartridge into the right slot.
    Figure : Insert the cartridge
  4. Close the cartridge door.
    Figure : Close the cartridge door
Step nine: Align the cartridges
After you insert the cartridges, a message displays indicating that the product is ready for alignment.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray, and then press OK.
    Figure : OK button on the control panel
  2. The product prints a cartridge alignment sheet.
    If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
  3. Load the alignment sheet on the scanner glass for scanning.
  4. Press OK to begin the alignment.
  5. The product aligns the cartridges. Recycle or discard the cartridge alignment sheet.
Step ten: Set the date and time
  1. Press the Setup button ()
  2. Press 6, and then press 3.
    This selects Tools, and then selects Date and Time.
  3. Enter the month, day, and year by pressing the appropriate numbers on the keypad. Depending on your country/region setting, you might enter the date in a different order.
  4. Enter the hours and minutes.
  5. If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM. The new date and time settings appear on the display.
Step eleven: Connect the supplied phone cord
Connect one end of the supplied phone cord to the phone port on the left (1-LINE) and the other to a wall jack.
Figure : Connect the phone cord
