HP Designjet Z3100 Photo Printer Series - Objects missing from the printed image
Large quantities of data may be necessary to print a high-quality large-format print job, and in some specific workflows there may be issues that can lead to some objects missing from the output. Here are some recommendations for the use of the Microsoft Windows driver dialog in these cases.
  • In the Advanced tab, select Document options, Printer features, and set Send job as bitmap to Enabled (HP-GL/2 driver only).
  • In the Advanced tab, select Document options, Printer features, and set 16-bit App. Compatibility to Enabled.
  • In the Advanced tab, select Document options, Printer features, and set Max. Application resolution to 300.
The above settings are mentioned for troubleshooting purposes and may adversely affect the final output quality or the time necessary to generate the print job. Therefore, they should be restored to their default values if they do not help to solve the problem.
If you are working under Mac OS, the above settings are not available. Instead, you could try reducing the resolution of bitmap images in your application software.
