HP Designjet Z3100 Photo Printer Series - Choose paper spindle
Ensure you use the correct spindle. You must use the gray spindle if you are loading the following categories and types of rolled papers wider than 36 in (91.5 cm).
Paper category
Paper type
Bond and Coated Paper
Plain Paper
Bright White Bond Paper
Coated Paper
Technical Paper
Natural Tracing Paper
Technical Paper
Translucent Bond
Technical Paper
Vellum
If you are a regular user of different paper types, you can change rolls more quickly if you preload rolls of different paper types on different spindles.
