HP Designjet Z3100 Photo Printer Series - Turn the buzzer on and off
To turn the printer's buzzer on or off, press the Menu key to return to the main menu and select the Setup menu icon , then Front panel options, Enable buzzer, and highlight on or off and press the OK key. The default buzzer is set to on.
