HP Designjet Z3100 Photo Printer Series - Front panel explanation
Your printer's front panel is located on the front of the printer, in the center. It has the following important functions:
  • Assists you in troubleshooting issues
  • Is used to perform certain procedures, such as cutting and unloading paper
  • Displays helpful animations to guide you through procedures
  • Displays up-to-date information about the status of the printer such as, the ink cartridges, the printheads, the paper, and the print jobs
  • Displays warning and error messages, when appropriate, along with audio alerts to call attention to a warning or message
  • Can be used to change the values of printer settings and thus change the operation of the printer. However, settings in the front panel are overridden by settings in the printer drivers.
Figure : Front panel
The front panel has the following components:
  1. Direct access keys:
    • First key: View ink levels.
    • Second key: View loaded pape.
    • Third key: Unload paper.
    • Fourth key: Form feed and cut.
  2. Menu key - Press to return to the main menu of the front-panel display. If you are already on the main menu it will display the status screen.
  3. OK key - To confirm an action while in a procedure or interaction. To enter in a submenu in the menu. To select a value when given an option.
  4. Back key - To go to the previous step in a procedure or interaction. To go to the upper level, or leave the option in the menu, or when given an option.
  5. Down key - To go down in a menu or option, or to decrease a value, for example when configuring the front-panel display contrast or the IP address.
  6. Up key - To go up in a menu or option, or to increase a value, for example when configuring the front-panel display contrast or the IP address.
  7. Cancel key - To abort a procedure or interaction.
  8. Power key - To turn the printer off or on, it also has a light to indicate the printer's status. If the power key light is off the device is off. If the power key light is blinking green, the device is starting up. If the power key light is green on, the device is on. If the power key light is amber on, the device is in standby. If the power key light is blinking amber, the device needs attention.
  9. LED light - Indicates the printer's status. If the LED light is solid green, the device is ready. If it is flashing green, the device is busy. If it is solid amber, there is a system error. If it is flashing amber, the printer needs attention.
  10. Front-panel display - Displays error, warnings, and information on using your printer.
To highlight an item in the front-panel display, press the Up or Down key until the item is highlighted.
To select an item in the front-panel display, first highlight it and then press the OK key.
When this guide shows a series of front-panel display items like this: Item1 > Item2 > Item3, it means that you should select Item1, then select Item2, then select Item3.
Information about specific uses of the front panel can be found throughout this guide.
