    We are upgrading our website
HP Photosmart M627, M627v, and M627xi Digital Cameras - Product Specifications
Figure : HP Photosmart M627 digital camera
Printer model
Part number
L2420A
HP Photosmart M627v digital camera
L2422A
HP Photosmart M627xi digital camera
L2421A
Feature
Resolution
Still pictures:
  • 7.4 MP (3152 by 2342) total pixel count
  • 7.0 MP (3040 by 2288) effective pixel count
Video clips:
  • 640 by 480 total pixel count, 22 frames/sec
Sensor
Diagonal 7.26 mm (1/2.5-inch, 4:3 format) CCD
Color depth
36 bit (12 bits by 3 colors). 36 bit images are transformed into an optimized 24 bit image and stored in the JPEG format. This transformation results in no discernible change to color or detail in the stored image, and allows the image to be read by computers.
Lens
Focal length:
  • Wide - 6.25 mm
  • Telephoto - 17.25 mm
  • 35 mm equivalent - Approximately 36 mm to 108 mm
F-Number:
  • Wide - f/2.8 to f/8
  • Telephoto - f/4.8 to f/7.6
Viewfinder
None
Zoom
3x optical zoom with 8 positions between wide and telephoto, 7x digital zoom
Focus
Focus settings: Normal (default), Macro
  • Normal
  • Wide - 500 mm (20 inches) to infinity
  • Telephoto - 600 mm (23.6 in) to infinity
  • Macro
  • Wide - 100 mm to 800 mm (3.9 to 31.5 inches)
Shutter speed
1/2000 to 2 seconds
Built-in flash
Yes, 6-second typical recharge time (8-second maximum recharge time at power-on)
Flash working distance
Zoom position
Maximum (Auto) ISO
Wide
3.8 m
12.5 feet
Telephoto
2.1 m
6.9 feet
Uniformity
Corner intensity > 55% of Center intensity (Lux Seconds)
Image Display
6.35 cm (2.5 in) color LTPS TFT LCD with backlight, 153,600 pixels (640 by 240) total pixel count
Storage
  • 16 MB internal flash memory
  • Slot for memory card
  • This camera supports standard and high speed, HP-branded Secure Digital (SD) memory cards, 8 MB to 2 GB.
  • The number of images that can be saved in memory depends on the Image Quality settings.
Compression format
  • JPEG (EXIF) for still images
  • EXIF2.2 for still images with embedded audio
  • Motion JPEG for video clips
Interfaces
Dock connector—Foxlink FPA25420–HP, which connects to either:
  • HP Photosmart 6220 camera dock
  • HP Photosmart 6221 premium camera dock
Standards
  • PTP—MSDC and SIDC
  • USB
  • JPEG
  • Motion JPEG
  • DPOF 1.1
  • EXIF 2.2
  • DCF 1.0
  • DPS
Power
Typical power usage: 2.5 Watts (with Image Display on). 5 Watts peak power usage.
Power sources include the following:
  • Two rechargeable NiMH batteries
  • Integrated AC power supply for worldwide operations—100 to 240 VAC, 50/60 Hz, country/region-specific power cord
Charge current – Rapid charge current—2.0A, two batteries – Trickle charge current—50mA
Temperature range – Operational—0° to 45° C (32° to 113° F) – Storage—–30° to 70° C (–22° to 158° F)
External body dimensions (W x D x H)
Measurements with camera off and lens retracted:
3.74 x 1.22 x 2.44 in; 95 x 31 x 62 mm
160 grams (5.64 ounces) without battery
Temperature range
Operational:
0° to 50° C (32° to 122° F) at 15% to 85% relative humidity
Storage:
–30° to 65° C (–22° to 149° F) at 15% to 90% relative humidity
Memory capacity
Quality setting
Approximate number and average size
7 MP Best
3 images (2.63-3.04 MB each)
7 MP (default)
10 images (1.03-1.18 MB each)
5 MP
12 images (741-916 KB each)
2 MP
32 images (348-404 KB each)
VGA
92 images (120 KB each)
The values shown are for images without audio clips. Sixty seconds of audio adds 330KB to the file size.
Country: Flag Bulgaria
