If the ERROR lamp lights, check the message displayed
on the front panel. There are the following types of error messages:
Service errors: operator unrecoverable errors, such as hardware or software failureContact HP Support.
Communication protocol errorsTake appropriate measures according to the error code or message.
Operator errorsThe operator can correct these errors. Take appropriate measures according to the message.
The error messages are as follows. Take appropriate measure
according to the error message.
note:If a communication error or a data error occurs, the ERROR lamp does not light. An error message appears on the front panel and disappears when the next operation is performed.
