HP Photosmart C6100 All-in-One Series - Installing the Ink Cartridges
This document contains information about installing the ink cartridges.
Install the print cartridges
The HP All-in-One must be on before you can insert the print cartridges.
  1. After you press the On button, wait for the prompt on the color graphics display before continuing.
  2. Open the access door by lifting it until it stops.
    Figure : Opening the access door
  3. Squeeze the bottom of each latch to release it, and then lift the latch.
    Figure : Release latch
  4. Lift all six latches.
    Figure : All latches lifted
  5. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage.
    1. Push the black ink cartridge into the first slot on the left. Close the latch.
      Figure : Black ink cartridge installation
    2. Repeat with each of the color ink cartridges.
      Figure : Color ink cartridge installation
    3. Make sure each latch is secure.
      Figure : All cartridges installed
      Use only the ink cartridges that came with the printer. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup.
  6. Close the access door and follow the prompts on the color graphics display.
