HP Photosmart C6100 All-in-One Series - An 'Ink cartridge(s) are empty' Error Message Displays on the Printer
Issue
An Ink Cartridge(s) are Empty error message displays on the printer. The indicated ink cartridge(s) are out of ink.
Solution
Replace the indicated ink cartridge(s) with new ink cartridge(s).
  1. Verify that the unit is on.
  2. Open the ink cartridge door.
    Figure : Opening the ink cartridge door
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch.
      Figure : Lifting the latch
    1. Ink cartridge latch for the black ink cartridges
    2. Ink cartridge latches for the color ink cartridges
    The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
  4. Pull the ink cartridge toward you out of its slot to remove it.
    Figure : Removing an ink cartridge
  5. Remove the new ink cartridge from its packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted.
    Figure : Inserting an ink cartridge
  7. Press down on the gray latch until it clicks into place.
    Figure : Closing the gray latch
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
Country: Flag Bulgaria
