HP Compaq nw9440 Workstation PC - Overview
Product description
HP Compaq nw9440 Mobile Workstation provides workstation-caliber performance, powerful graphics capabilities, and a 17-inch widescreen display for high-end computing wherever work takes you
Product Features
Feature
Processor, operating system and memory
Operating systems included
Microsoft® Windows® XP Professional,
FreeDOS
Processor type
Intel® Core™ Duo processors T2400 to T2600 Processor features
min: Intel® Core™ Duo processor T2400 (1.8-GHz, 667-MHz FSB, 2-MB L2 cache)
max: Intel® Core™ Duo processor T2600 (2.16-GHz, 667-MHz FSB, 2-MB L2 cache)
Memory description
min: 512 MB
max: 4096 MB
Video
Display size
17.0-inch WSXGA+ wide viewing angle display,
17.0-inch WSXGA+ wide viewing angle BrightView display or
17.0-inch WUXGA wide viewing angle display
Display resolution
VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz.
DVI port in optional HP Docking Station (sold separately) supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking.
Video adapter description
NVIDIA Quadro FX 1500M graphics controller with 256 MB of discrete video memory, Hardware OpenGL acceleration
Storage
Hard drive, internal
min: 60 GB (5400 rpm) SMART SATA
max: 100 GB (7200 rpm) SMART SATA
Optional modules
DVD-ROM; DVD/CD-RW Combo; DVD+/-RW SuperMulti with Double Layer; LightScribe DVD+/-RW with Double Layer.
Audio and ports
Audio
ADI High Definition CODEC; integrated 16-bit Sound Blaster Pro compatible audio; stereo speakers; directional microphone; external volume control and mute buttons; stereo headphone/line out; stereo microphone in.
I/O (input/output) ports
4 USB 2.0, VGA, mic in, line out, 1394, power, RJ-11, RJ-45, S-video TV out, docking connector, travel battery connector
Communications
10/100/1000 Broadcom NetXtreme Gigabit Ethernet PCI Express Controller with HP Smart Power NIC Technology 56K V.92 modem with digital line guard
Wireless
Choice of Broadcom 802.11b/g WLAN, Broadcom 802.11a/b/g WLAN, Intel PRO/Wireless 3945ABG 802.11 a/b/g WLAN, Intel PRO/Wireless 3945BG 802.11 b/g WLAN; Optional Integrated Bluetooth®
Slots
1 Type I/II PC Card slot which supports both 32-bit CardBus and 16-bit PC Cards; 1 integrated Smart Card Reader; 7-in-1 Media Reader
Power
External 120-watt smart AC adapter, 6-foot (1.8-meter) power cord included. Total length including External AC adapter is 12 feet (3.66 meter). 8-cell high capacity Lithium-Ion (69Wh). HP Fast Charge technology.
Keyboard
The 101/102-key compatible keyboard features an industry standard, full-width layout with desktop keyboard features such as isolated inverted-T cursor control keys, left and right control and alt keys, and 12 function keys. Other features include a full numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 19.05 mm x 19.05 mm key pitch (center-to-center spacing), 3.0 mm stroke, comfort-dished keycaps, and bright key legends for improved visibility in low light conditions.
Mouse / pointing device
Dual pointing devices – Pointstick with three soft-touch buttons and Touchpad with scroll zone and three soft-touch buttons (or two soft-touch buttons and HP Biometric Fingerprint Sensor)
Mobility
7.5 lb.
Dimensions (L x W x H)
10.8 x 15.5 x 1.3 in.
Manageability
Security management
HP ProtectTools Security Manager, Configuration Control Hardware, Memory Change Alert, Ownership Tag, Setup Password, Power-On Password, Drivelock, TPM Enhanced Drivelock, HP Disk Sanitizer, Kensington Lock Slot, Integrated Smart Card Reader, TPM Embedded Security Chip, HP Biometric Fingerprint Sensor.
Three-years standard parts and labor warranty, pick-up or carry-in, and toll-free 7 x 24 hardware technical phone support. On-site service and warranty upgrades are also available.
