    Fix Windows 10 Update Issues
HP Photosmart A610, A612, A616, A617, and A618 Printers - Product Specifications
HP Photosmart printer models
Figure : HP Photosmart A610 Series Printer
HP Photosmart A610
Q7114A
HP Photosmart A612
Q7115A
HP Photosmart A616
Q7112A
HP Photosmart A617
Q7117A
HP Photosmart A618
Q7118A
System requirements
Component
Windows PC
Macintosh
Microsoft Windows 98 SE, 2000, Me, XP Professional, XP Home, XP Starter Edition, and XP Professional x64
Mac OS X 10.3.x, and 10.4.x
Processor
Intel Pentium II (or equivalent) or greater.
G3 or greater
RAM
64 MB (255 MB recommended)
128 MB
Free disk space
500 MB
150 MB
Video display
800 x 600, 16-bit or higher
CD-ROM drive
4x
4x
Connectivity
USB 2.0 full-speed: Microsoft Windows 98 SE, Me, 2000 Professional, XP Home, XP Professional, XP Starter Edition, and XP Professional x64
PictBridge: using front camera port
Bluetooth: using an integrated-Bluetooth printer or optional HP Bluetooth wireless printer adapter
USB: Mac OS X 10.3.x and 10.4.x
Browser
Microsoft Internet Explorer 5.5 or more current
Printer specifications
Specification
Details
Image file formats
JPEG Baseline
Margins
Borderless printing:Top 0.0 mm (0.0 inch); Bottom 12.5 mm (0.50 inch); Left/right 0.0 mm (0.0 inch)
Bordered printing: Top 3 mm (0.12 inch); Bottom 12.5 mm (0.50 inch); Left/right 3 mm (0.12 inch)
Media sizes
Photo paper 10 x 15 cm (4 x 6 inches) or 13 x 18 cm (5 x 7 inches)
Photo paper with tab 10 x 15 cm with 1.25 cm tab (4 x 6 inches with 0.5 inch tab)
Photo sticker paper 10 x 15 cm (4 x 6 inches), 16 rectangular or oval stickers per page
Panorama photo paper (for pre-stitched images) 10 x 30 cm (4 x 12 inches)
Index cards 10 x 15 cm (4 x 6 inches)
Hagaki cards 100 x 148 mm (3.9 x 5.8 inches)
A6 cards 105 x 148 mm (4.1 x 5.8 inches)
L-size cards 90 x 127 mm (3.5 x 5 inches)
L-size cards with tab 90 x 127 mm with 12.5 mm tab (3.5 x 5 inches with 0.5 inch tab)
Media types
HP Advanced Photo Paper
Cards: index, Hagaki, A6, L-size, 2L-size
Photo sticker paper
HP CD/DVD Label tattoo
HP Self-Adhesive Photo Paper
Memory cards
CompactFlash Type I and II
MultiMediaCard
Secure Digital
Memory Sticks
Microdrive
xD-Picture Card
Memory card-supported file formats
Printing: All supported image and video file formats
Saving: All file formats
Paper tray
One 13 x 18 cm (5 x 7 inches) photo paper tray
Paper tray capacity
Up to 20 sheets depending upon paper thickness.
20 sheets of photo paper, maximum thickness 292 µm (11.5 mil) per sheet
Power consumption
U.S.
Printing: 15.14 W
Idle: 8.61 W
Off: 6.66 W
International
Printing: 14.04 W
Idle: 8.61 W
Off: 7.06 W
Power adapter
HP Part # 0957–2121 (North America), 100–240 V AC (±10%) 50/60 Hz (±3 Hz)
HP Part # 0957–2120 (Rest of world), 100–240 V AC (±10%) 50/60 Hz (±3 Hz)
Print cartridge
HP 110 Tri-color Inkjet print cartridge
USB 2.0 high-speed support
HP recommends that the USB cable be less than 3 meters (10 feet) in length
Video file formats
Motion JPEG AVI
Motion-JPEG QuickTime
MPEG-1
Print resolution
Black and Color: PhotoREt III, 4800 x 1200 optimized dpi in printer driver
Print speed
Printer mode
Speed
Normal mode
Up to 60 seconds per page
Print Quality mode
Up to approximately 100 seconds per page
Input/output
  • Front and rear USB ports: 2.0 full speed, supporting connection to a computer, notebook computer, and selected HP cameras
  • Bluetooth wireless printing compatible
  • PictBridge camera compatible
Physical dimensions
Dimension
Size
Height, width, depth
249 x 122 x 114 mm (9.8 x 4.8 x 4.5 inches)
1.5 kg (3.3 lbs)
Environmental specifications
Specification
Operating temperatures
Maximum during operation
5–40° C (41–104° F), 5–90% RH
Recommended during operation
15–35° C (59– 95° F), 20–80% RH
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309. Plastic parts over 24 grams (0.88 ounces) are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the printer's life.
Material safety data sheets
Material Safety Data Sheets (MSDS) can be obtained from the HP Web site at www.hp.com/go/msds. Customers without Internet access should contact HP support.
Recycling program
HP offers an increasing number of product return and recycling programs in many countries and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. This HP product contains lead in the solder, which may require special handling at the end of its life.
