    Fix Windows 10 Update Issues
HP iPAQ rw6800 Multimedia Messenger Series - Overview
Product Description
Product Features
Feature
Processor
Intel® PXA272 Processor 416 MHz NOTE: Intel's processor numbering is not a measurement of higher performance.
Total Memory Size
128 MB flash ROM for persistent storage
64 MB SDRAM main memory for running applications
Type Transmissive QVGA color TFT LCD with LED backlight & power save mode
Number of Colors 18-bit (262,144) colors NOTE: OS supports up to 16-bit (65,536) colors only
Touch Screen Yes
Resolution (W x H) 240 x 320 pixels
Dot Pitch 0.057(H) x 0.171(V) mm
Viewable Image Size 2.7 in (68 mm) diagonal
System Unit
Dimensions (H x W x D) 4.02 x 2.28 x 0.77 in (102 x 58 x 19.5 mm) NOTE: Not including an LCD-protective flip cover
Weight 4.94 oz (140 g)
Operating Temperature 32° to 104° F (0° to 40° C)
Storage Temperature -4° to 140° F (-20° to 60° C)
Operating Humidity 90% RH
Regulatory Marks Environmental: Wee logo All required regulatory marks for the intended markets
HP Photosmart Camera
Resolution UXVGA/SXGA/CIF, 2 Mega pixels CMOS with LED light
Image Quality 1,600 x 1,200 pixels
File Format Supported
  • Still image formats – JPEG:
    XGA – 800 x 600
    VGA – 640 x 480
    QVGA – 320 x 240
    QQVGA – 160 x 120
  • Video formats – 3GP (H.263)
    CIF – 352 x 288
    QCIF – 176 x 144
    SQCIF – 128 x 96
  • High Quality F/2.8 Lens, with focus set to 1.8M
  • LED light
  • Self-portrait mirror
Hardware Buttons/ Reset Buttons
1 power button, 1 reset button, 2 soft key buttons, 1 voice record button, 1 camera/video button (dual function), 1 up and 1 down volume control button, 1 phone answer/send button with green phone icon, 1 end call button with red phone icon, 1 4-way navigation button and 1 select button
Stylus
1 included in the system box
Audio
Input
Voice recording and voice commander using built-in speakerphone, microphone on the bottom of unit, or microphone input jack (combined with headphone jack)
Output
Dual stereo speakers on the front of unit, 2.5mm handset earpiece audio/microphone jack with stereo sound 3D widening/bass boost/treble adjustment LifeVibes™ Concert Sound EX
The audio driver supports 8.0, 11.025, 16, 22.05 and 44.1 KHz playback sample rates. Audio codecs: WMA, MP3, Simple MIDI, AMR-NB, polyphonic MIDI
Indicators
LED 1 – Charge and Notify
Flashing Green LED – within GSM coverage area
Flashing Amber LED – event notification / alarm
Solid Amber LED – battery charging (Charger connected)
Solid Green LED – battery fully charged (Charger connected)
LED 2 – Bluetooth
Flashing Blue LED – Bluetooth ON
Flashing Blue LED – WLAN ON
Phone Notification
Vibrate
Audible
Visual message on the display
External Interfaces
Connector
1 mini-USB connector for synchronization and charging
Other Interfaces
IrDA (SIR) port
Some HP authorized options with IrDA may not be supported. See http://www.hp.com/go/ipaqaccessories.
Mini SD Slot
Supports 4-bit mini-SD memory standard
Power
Battery
Removable and rechargeable 1,530 mAh Lithium-Polymer battery Additional batteries available for purchase (http://www.hp.com/go/ipaqaccessories).
Battery Performance
Continuous talking time: approximately 5.5 hours
Continuous standby time: approximately 240 hours
Talking, standby, and usage times are approximate and depend on the network configurations, usage patterns of an individual user and handheld device configurations. Use of internal wireless capabilities, GPS and backlight will significantly decrease battery run time.
AC Adapter
2.96 x 1.81 x 1.24 in (75.32 x 45.96 x 31.67 mm – including prongs), (may vary by model)
Cord Length (approx.)
3.94 ft (1.2 m) USB cable length only
Power Supply Ratings
Voltage Range 100 to 240 Vac
Input Current 0.15A (RMS) 120VAC at Max. load. 0.08A (RMS) 230VAC at Max. load.
Input Frequency 50 to 60 Hz
Output Voltage 5.0 VDC (typical)
Output Current 1.0 Amp (typical)
In the box
HP iPAQ rw6818 (rw6828 for WLAN SKUs) Multimedia Messenger, 1,530mAh Lithium-Polymer removable and rechargeable battery, free-voltage AC adapter, wired stereo headphones, 2 LCD-protective flip covers (grey and green for rw6818 SKUs, and grey and blue for rw6828 SKUs), mini-USB synchronization cable, stylus, leather holster, product information guide, warranty card, HP & Microsoft EULA card, Getting Started CD
Service and Support
One-year Limited Warranty on parts and labor with Carry-In service; 90 days technical support for software in Asia-Pacific regions. Additional offers may vary by country
Software Overview
Feature
Operating System
Microsoft® Windows Mobile® 5.0 software for Pocket PC, Phone Edition with Messaging and Security Feature Pack Mobile versions of Microsoft Office software include (Word®, Excel®, PowerPoint® and Internet Explorer) Microsoft® Outlook™ 2002 for Pocket PC
Operating System Applications for Phone Edition
Powered by Microsoft® Windows Mobile® 5.0 – Phone Edition: Calendar, Contacts, Tasks, Voice Recorder, Notes, Word Mobile, Excel Mobile, PowerPoint Mobile, Internet Explorer Mobile, Windows Media Player 10 Mobile, Calculator, Solitaire, Bubble Breaker, Wireless Manager, Device Lock, Messaging, Pocket MSN, File Explorer, Terminal Services Client, SIM Contacts, Settings
Additional Software and Links
Microsoft Outlook 2002, Microsoft ActiveSync 4.1 (Desktop device synchronization) and links to Microsoft websites for additional downloadable applications
Some programs may require purchase of additional desktop software to utilize Pocket PC versions
HP Exclusive Applications
HP Photosmart Camera – capture digital photos and video with the built-in 2 MP camera
HP Photosmart Mobile – view, organize and share photos, videos
Today Panel Lite – one touch access from Today Screen to device status: battery, memory, and backlight settings
HP Help and Support – one location for help, warranty, and support information
Modem Link – use the HP iPAQ as a modem to wirelessly connect a notebook PC to the Internet
PocketMind PocketMusic – MP3, OGG, WMA, WAV music player
FM Radio – FM radio tuner
Esmertec Java Virtual Machine (VM) – run Java applications on the Pocket PC
Auto Configurator – GSM network detection and settings
Download Agent – downloaded content management
Self Test – system self-testing tool
Cyberon Voice Commander – voice recognition and application launch software
Wi-Fi Utility (on rw6828 models only) – Wi-Fi status and settings information tool
Arcsoft MMS Composer – multimedia messaging service client
Philips Lifevibes™ Concert Sound EX – 3D widening, bass boot, treble adjustment
Getting Started CD applications from HP
Applications
Microsoft Outlook 2002 for PC
ActiveSync 4.1 for PC
HP Photosmart Premier for PC
HP Image Transfer for PC and Pocket PC
Real Player 10.5 for PC
Adobe Reader for PC application for PC
PocketMind CD to Mobile for PC
PDAMill GameBox Classic for Pocket PC
PDAMill GameBox Gems for Pocket PC
DIOTEK PowerDic Chinese-English Electronic Dictionary for Pocket PC (for selected models only)
CD Links
HP Web Registration
HP Handheld Software Store
HP Mobility Solution Evaluation Center
HP iPAQ Accessories
HP iPAQ Products
HP Help and Support
HP Worldwide Support Telephone Numbers
Windows Media Player 10 Desktop for PC
Microsoft Web Site for Windows Mobile-based Pocket PC
Additional Documentation
HP iPAQ Additional Product Information
HP Important Safety Information
"How Do I" Help Information
The Modem Link Software and Driver
Programs may vary based on model. Some programs are accessed through CD links to download web sites.
Links to Product Specification and Warranty Information
