HP Compaq nc2400 Notebook PC - Overview
Product description
The Ideal Travel Partner — Less than 3 lbs (1.34 kg), 12.1- inch widescreen display, and integrated optical drive support
Product Features
Feature
Processor
Intel Core Solo Processor U1400† (1.20-GHz, 533-MHz FSB, 2-MB L2 cache)
Intel Core Solo Processor U1300† (1.06-GHz, 533-MHz FSB, 2-MB L2 cache)
Intel Celeron M Processor 423† (1.06-GHz, 533-MHz FSB, 1-MB L2 cache)
Intel’s numbering is not a measurement of higher performance.
Mobile Intel 945GM Express Chipset
Memory
DDR2 SDRAM, 533-MHz, one SODIMM slot, 256/512/1024/2048-MB
Hard drive(s)7
30/40/60-GB 4200 rpm
Removable media12
9.5-mm optical drives: DVD+/-RW SuperMulti5 with Double Layer1, 24x DVD/CD-RW Combo, 8x DVD-ROM
12.1-inch WXGA (1280 x 800 resolution and 16M colors)
Graphics11 l
Intel Graphics Media Accelerator 950, up to 128-MB shared system memory
Audio
PremierSound High Definition Audio support w/24-bit DAC, headphone jack, microphone jack
Wireless2 support
Intel PRO/Wireless 3945BG Network Connection, Intel PRO/Wireless 3945ABG Network Connection, Broadcom 4311BG 802.11b/g WiFi Adapter, Broadcom 4311AG 802.11a/b/g WiFi Adapter, dual display mounted antennas, Bluetooth™ 2.0
Communications
Broadcom NetLink Gigabit Ethernet PCI Controller3 (10/100/1000 NIC), 56K v.92 modem, HP Smart Power NIC technology
1 Type I/II PC Card slot supports 32-bit CardBus and 16-bit cards or integrated Smart Card Reader
Ports and connectors 2
USB 2.08, VGA, RJ-11, RJ-45, headphone, microphone, IEEE 1394a, docking connector, AC adapter
Input devices
Full-sized keyboard; Pointstick with two pick buttons
Touch-sensitive controls
HP Info Center, wireless on/off, presentation mode, volume control
Dimensions (h × w × d)
0.976 in (at front) x 11.1 in x 8.38 in /24.8 mm (at front) x 282.3 mm x 212.8 mm
Starting at 2.96 lb/1.34 kg
Power
3-cell (28 WHr), 6-cell (55 WHr), or 9-cell (83 WHr) Lithium-Ion battery, 65W HP Smart AC Adapter9, HP Fast Charge Technology4
Three-year standard parts and labor limited warranty, depending on country (upgrades available6), one-year limited warranty on primary batteries
Software Overview
Feature
Preinstalled
Microsoft Windows XP Professional Edition
Microsoft Windows XP Home Edition
FreeDOS
Supported
Microsoft Windows 2000 (drivers downloadable from http://www.hp.com)
Security and recovery
HP Backup and Recovery Manager
Norton Internet Security
HP ProtectTools Security Manager
Applications
Sonic Digital Media Plus – select models
Intervideo WinDVD 5 – select models
Microsoft Office 2003 Small Business or Professional- Optional
Security
HP ProtectTools, HP Drivelock, optional Smart Card Reader6, integrated HP Biometric Fingerprint Sensor, TPM Embedded Security Chip , Kensington lock slot
Additional Information
1.Double Layer discs can store more data than single layer discs. However, double-layer discs burned with this drive may not be compatible with many existing single-layer DVD drives and players
2. Wireless access point required and is not included. Availability of public wireless access points limited. Wireless Internet use requires separately purchased Internet service contract.
3. The term "10/100/1000" or "Gigabit" Ethernet indicates compliance with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/sec. For high speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
4. Fast Charge Technology recharges your battery up to 90% within 90 minutes when the system is off. Fast Charge Technology does not apply to 9 cell primary.
5. Note that DVD-RAM cannot read or write to 2.6GB Single Sided/5.2 GB Double Sided – Version 1.0 media.
6. Sold separately or as an optional feature.
7. For hard drives, GB = 1 billion bytes. Actual formatted capacity is less. Up to 8GB of memory is reserved for system recovery software.
8. One of the USB ports is powered for units configured without an optical drive only
9. The new HP Smart A/C Adapters will not be backwards compatible to prior generation notebooks. However, a dongle will be available to support existing notebooks in the field. Older HP adapters will not be forward compatible to the 2006 HP Business Notebooks
10. Battery life will vary depending on the product: model, configuration, loaded applications, features, and power management settings. The maximum capacity of the battery will decrease with time and usage.
11. Shared video memory (UMA) uses part of the total system memory for video
