    Fix Windows 10 Update Issues
Printer Specifications for HP Photosmart D6160, D6163, and D6168 Printers
HP Photosmart printer models
Printer model
Part number
HP Photosmart D6160 printer
C9089A, C9089B
HP Photosmart D6163 printer
C9089C
HP Photosmart D6168 printer
C9089D
System requirements
Component
Windows
Macintosh
Microsoft Windows 98 SE, 2000 Professional, Me, XP Home, and XP Professional
Mac OS X 10.3, 10.4, and later
Processor
Intel Pentium II (or equivalent) and higher
G3 or greater
RAM
64 MB (128 MB recommended)
Mac OS X 10.3, 10.4, and later: 128 MB
Free disk space
500 MB
150 MB
Video display
800 x 600, 16-bit or higher
CD-ROM drive
4x
4x
Connectivity
USB: Microsoft Windows 98, 2000 Professional, Me, XP Home, and XP Professional
PictBridge: using front camera port
Bluetooth: using optional HP Bluetooth Wireless Adapter
USB: Front and back ports (Mac OS X 10.3, 10.4, and later)
Internet Explorer version
Microsoft Internet Explorer 5.5 or later
Ink cartridges
  • HP 02 Yellow Ink Cartridge
  • HP 02 Cyan Ink Cartridge
  • HP 02 Light Cyan Ink Cartridge
  • HP 02 Magenta Ink Cartridge
  • HP 02 Light Magenta Ink Cartridge
  • HP 02 Black Ink Cartridge
Print speed
Draft Mode Speed Black/Color
Up to 32 pages per minute
Up to 4.3 pages per minute
Duty cycle
Up to 3000 pages per month.
Supported paper sizes
Specification
Details
Supported sizes when printing from a computer
Width: 76 to 216 mm (3 to 8.5 inches)
Length: 127 to 610 mm (5 to 24 inches)
Supported sizes when printing from the control panel
A4: 210 x 297 mm (8.3 x 11.7 inches)
10 x 15 cm (4 x 6 inches) with tab
10 x 15 cm (4 x 6 inches) without tab
89 x 127 mm (3.5 x 5 inches)
102 x 305 mm (4 x 12 inches)
127 x 178 mm (5 x 7 inches)
203 x 254 mm (8 x 10 inches)
216 x 279 mm (8.5 x 11 inches)
Hagaki: 100 x 148 mm (3.9 x 5.8 inches)
Print margin specifications
Paper size
Top (leading edge)
Bottom (trailing edge)
Left and Right margins
US Letter
US Legal
US Executive
1.75 mm (0.069 inches)
14.2 mm (0.56 inches)
3 mm (0.12 inches)
ISO A4
ISO A5
JIS B5
3 mm (0.12 inches)
Envelopes
3 mm (0.12 inches)
Cards
3 mm (0.12 inches)
Input/output
  • Rear USB port: 2.0 full speed, supporting connection to a computer, notebook computer. and selected HP cameras with HP Direct Printing
  • Front camera port: selected HP cameras with HP Direct Printing
  • Bluetooth wireless printing compatible with optional Bluetooth adapter
  • PictBridge camera compatible through printer's front USB port
  • HP Instant Share
Paper tray capacity
Tray
Capacity
Main tray:
Up to 100 sheets of plain paper
Up to 14 envelopes
Up to 20–40 cards (depending on thickness)
Up to 30 sheets of labels
Up to 25 transparencies, iron-on transfers, or photo paper
Up to 20 sheets of photo paper
Photo tray:
Up to 50 sheets of plain paper
Up to 10 cards or envelopes
Output tray:
Up to 14 envelopes
Up to 20-40 cards (depending on thickness)
Up to 25 sheets of labels or iron-on transfers, or photo paper
Physical dimensions
Height, width, depth
17.29 cm (6.81 inches) x 46.25 cm (18.21 inches) x 38.73 cm (15.25 inches)
7.37 kg (16.2 pounds)
Operating environment
Recommended temperature range
15–30° C (59-86° F)
Maximum temperature range
5–40° C (41-104° F)
Storage temperature range
-40–60° C (-40-140° F)
Recommended humidity range
20–80% RH
Maximum humidity range
10–80% RH
Environmental specifications
Hewlett-Packard Company is committed to providing quality products in an environmentally sound manner. This printer has been designed with several attributes to minimize impact on HP's environment. For more information, go to HP's Commitment to the Environment Web site (in English).
Ozone production
This product generates no appreciable ozone gas (O3).
Energy consumption
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products. ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information on ENERGY STAR guidelines, go to the Energy Star Web site.
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309. Plastic parts over 24 grams (0.88 ounces) are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the printer's life.
Material Safety Data Sheets
To view Material Safety Data Sheets (MSDS), go to http://www.hp.com/go/msds (in English).
Recycling program
HP offers an increasing number of product return and recycling programs in many countries/regions and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. This HP product contains lead in the solder, which may require special handling at the end of its life.
