HP Photosmart A510, A512, and A516 Printers - Product Specifications
Figure : HP Photosmart A510 printer
This document outlines the product specifications for the HP Photosmart A500 series printer.
HP Photosmart printer models
Q7024A
HP Photosmart A512 printer
Q7025A
HP Photosmart A516 printer
Q7021A
System requirements
Component
Windows PC
Macintosh
Windows 98se, 2000 Professional, Me, XP Home, XP Professional, XP Starter Edition, and XP Professional x64
OS X v 10.3.x, 10.4.x
There is no support for OS 9 or OS X Classic Mode for this printer.
Processor
Pentium II (or equivalent) or greater
G3 or greater
RAM
64 MB (256 MB recommended)
128 MB
Free disk space
500 MB
500 MB
Video display
800 x 600, 16-bit or higher
CD-ROM drive
4x
4x
Connectivity
USB 2.0 high-speed: Windows 98, 2000 Professional, Me, XP Home, and XP Professional, and XP Professional x64
PictBridge: using front camera port
Bluetooth: using optional HP Bluetooth wireless printer adapter (Windows XP only)
USB 2.0 high-speed: Mac OS X v 10.3.x, v 10.4.x
Browser
Microsoft Internet Explorer 5.5 or more current
Printer specifications
Specification
Details
Image file formats
JPEG Baseline TIFF 24-bit RGB uncompressed interleaved
TIFF 24-bit YCbCr uncompressed interleaved
TIFF 24-bit RGB packbits interleaved
TIFF 8-bit gray uncompressed/packbits
TIFF 8-bit palette color uncompressed/packbits
TIFF 1-bit uncompressed/packbits/1D Huffman
Margins
Borderless printing:
Top 0.0 mm (0.0 inch)
Bottom 12.5 mm (0.50 inch)
Left/right 0.0 mm (0.0 inch)
Bordered printing:
Top 3 mm (0.12 inch)
Left/right 3 mm (0.12 inch)
Media sizes
Photo paper 10 x 15 cm (4 x 6 inches)
Photo paper with tab 10 x 15 cm with 1.25 cm tab (4 x 6 inches with 0.5 inch tab)
Photo sticker paper 10 x 15 cm (4 x 6 inches), 16 rectangular or oval stickers per page
Panorama photo paper (for pre-stitched images) 10 x 30 cm (4 x 12 inches)
Index cards 10 x 15 cm (4 x 6 inches)
Hagaki cards 100 x 148 mm (3.9 x 5.8 inches)
A6 cards 105 x 148 mm (4.1 x 5.8 inches)
L-size cards 90 x 127 mm (3.5 x 5 inches)
L-size cards with tab 90 x 127 mm with 12.5 mm tab (3.5 x 5 inches with 0.5 inch tab)
Media types
HP Advanced Photo paper
Cards: index, Hagaki, A6, and L-size
Photo sticker paper
Memory Cards
CompactFlash Type I and II
Memory Sticks
Microdrive
MultiMediaCard
Secure Digital
SmartMedia
xD-Picture Card
Memory card-supported file formats
Printing: All supported image and video file formats
Saving: All file formats
Paper tray
One 10 x 15 cm (4 x 6 inches) photo paper tray
Paper tray capacity
20 sheets of photo paper, maximum thickness 11.5 mil per sheet.
Environmental specifications
Maximum during operation: 5–40° C (41–104° F), 5–90% RH
Recommended during operation: 15–35° C (59– 95° F), 20–80% RH
Power consumption
U.S.
Printing: 14.46 W
Idle: 8.67 W
Off: 6.63 W
International
Printing: 12.0 W
Idle: 8.41 W
Off: 7.19 W
Video file formats
Motion JPEG AVI
Motion JPEG QuickTime
MPEG-1
Power module
HP Part number 0957-2121 (North America)
Input voltage: 100-240 VAC (+/- 10%)
Input frequency: 50/60 Hz (+/- 3 Hz)
HP Part number 0957-2120 (Rest of World)
Print cartridge
HP 110 Tri-color Inkjet print cartridge
USB 2.0 high-speed support
Microsoft Windows 98, 2000 Professional, Me, XP Home, and XP Professional
Mac OS X 10.3.x, 10.4.x
HP recommends the USB cable be less than three meters (10 feet) in length.
Connectivity
USB 2.0 high-speed: Microsoft Windows 98, 2000 Professional, Me, XP Home, XP Professional, and XP Professional x64; Mac OS X 10.3.x, 10.4.x
PictBridge: Microsoft Windows 98, 2000 Professional, Me, XP Home, XP Professional, and XP Professional x64; Mac OS X 10.3.x, 10.4.x
Bluetooth: Microsoft Windows XP Home and XP Professional
Print resolution
Black and Color
PhotoREt III, 4800 x 1200 optimized dpi in printer driver
Print speed
Normal mode
60 seconds per page
Print Quality mode (4x6)
Approximately 100 seconds per page
Internal memory
16 MB
New features
  • Print colorful, borderless photos
  • Improve dark areas of image, sharpen blurred photos, reduce red eye, and improve overall brightness and contrast
  • Panoramic print mode
  • Sticker print mode
  • Photo Fix button
Physical dimensions
Height, width, depth
4.9 x 8.8 x 4.3 inches (125 x 225 x 110 mm)
2.93 pounds (1.33 kg)
Operating environment
5-40 degrees C (41-104 degrees F), 5-90% RH
15-35 degrees C (59-95 degrees F), 20-80% RH
Hewlett-Packard Company is committed to providing quality products in an environmentally sound manner. This printer has been designed with several attributes to minimize impact on HP's environment. For more information, go to HP's Commitment to the Environment Web site at www.hp.com/hpinfo/globalcitizenship/environment/.
Ozone production
This product generates no appreciable ozone gas (O3).
Energy consumption
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products. ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information, go to www.energystar.gov.
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309. Plastic parts over 24 grams (0.88 ounces) are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the printer's life.
Material safety data sheets
Material Safety Data Sheets (MSDS) can be obtained from the HP Web site at www.hp.com/go/msds. Customers without Internet access should contact HP support.
Recycling program
HP offers an increasing number of product return and recycling programs in many countries and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. This HP product contains lead in the solder, which may require special handling at the end of its life.
