Printer Specifications for HP Photosmart C4100 All-in-One Printer Series
This document applies to the following HP Photosmart All-in-One products:
  • C4110, C4140, C4150, C4170, C4173, C4175
  • C4180, C4183, C4188, C4190, C4193, C4194
Minimum system requirements - Windows
Typical installation
Supported operating system
Windows 98 SE
Windows Me
Windows 2000 Professional
Windows XP1
Windows 95, 3.1, NT 4.0, 2003 Server, and DOS are not supported.
Intel Pentium II (or equivalent compatible processor) or later
128 MB RAM
Available USB port
CD-ROM drive (4x)
800 x 600 monitor with 16-bit or higher color depth
Microsoft Internet Explorer 5.5 or later
Microsoft Internet Explorer 6.0 SP1 or higher required for Japanese and Finnish versions of Windows Me
1 Media center and Tablet editions are supported.
Recommended
  • Intel Pentium III or later processor
  • 256 MB RAM
  • SVGA 1024 x 768 display resolution with 24-bit color
  • Internet access
  • Sound card
  • Microsoft Internet Explorer 6.0 SP1 or higher is required for Japanese and Finnish versions of Windows Me.
  • Adobe Acrobat 4.0 or later
Minimum system requirements - Macintosh
Mac OS X v10.3.9
G3 processor or later
128 MB RAM
Available USB port
CD-ROM drive
800 x 600 display resolution with 16-bit or higher color depth
Recommended
  • G4 processor or later
  • 256 MB RAM for OS X
  • 1024 x 768 display resolution with 24-bit color
  • Internet access
  • Sound card
Connectivity
  • USB 2.0 Hi-speed: Microsoft Windows 98 SE, 2000 Professional, Me, XP Home, and XP Professional; Mac OS X 10.3 and later
USB support
Universal Serial Bus (USB): 2.0 Hi-speed compliant cable. 10 feet (3 meters) or less in length. (Microsoft Windows 98 SE, 2000 Professional, Me, XP Home, and XP Professional; Mac OS X 10.3 and later)
Print cartridges
  • 1 HP Black
  • 1 HP Tri-color
  • 1 HP Photo (optional)
  • 1 HP Grey (optional)
Print specifications
  • Method: Drop-on-demand thermal inkjet
  • Language: PCL3 GUI
  • Print speeds vary according to the complexity of the document
  • Up to 1200 x 1200 rendered dpi black
  • Up to 4800 x 1200 optimized dpi color
  • Duty cycle: Up to 3000 printed pages per month (maximum)
Mode
Speed (ppm) on plain paper
Speed (seconds) 4 x 6 inch)
Maximum dpi
Black
up to 0.4
as fast as 145.0
Color
up to 0.4
as fast as 145.0
Best
Black
up to 2.3
as fast as 74.0
Color
up to 2.3
as fast as 74.0
Normal
Black
up to 8.5
as fast as 54.0
Color
up to 5.3
as fast as 54.0
Fast
Black
up to 30
as fast as 27.0
Color
up to 24
as fast as 27.0
Copy specifications
  • Digital image processing
  • Resolution up to 4800 x 1200 optimized dpi output using a scan resolution of 1200 x 1200 dpi.
  • Up to 50 copies from original (varies by model)
  • Digital zoom up to 400% (fit to page)
  • Fit to page, Poster, Many on page
  • Up to 30 copies per minute black; 24 copies per minute color (varies by model)
  • Copy speeds vary according to the complexity of the document
Mode
Scan resolution (dpi)
Maximum dpi
Black
Up to 0.1
2400 x 4800 (48 bit scan)
Color
Up to 0.1
1200 x 1200
Best
Black
Up to 0.8
600 x 600
Color
Up to 0.8
600 x 600
Normal
Black
Up to 8.5
300 x 300
Color
Up to 5.1
300 x 300
Fast
Black
Up to 30
300 x 300
Color
Up to 24
300 x 300
Paper specifications
Paper sizes
Type
Size
Paper
Letter: 216 x 280 mm (8.5 x 11 inches)
A4: 210 x 297 mm (8.3 x 11.7 inches)
A5: 148 × 210 mm (5.8 x 8.3 inches)
Executive: 184.2 x 266.7 mm (7.25 x 10.5 inches)
Legal: (216 x 356 mm) (8.5 x 14 inches)
216 x 279 mm (8.5 x 11 inches)
Photo paper
102 x 152 mm (4 x 6 inches)
Envelopes
U.S. #10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. #9: 98 x 225 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Cards
76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
127 x 178 mm (5 x 7 inches)
A6: 105 x 148.5 mm
Hagaki postcard: 100 x 148 mm (3.94 x 5.83 inches)
Transparency film
Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Labels
A4: 210 x 297 mm
Custom
76 x 127 mm up to 216 x 356 mm (3 x 5 inches up to 8.5 x 14 inches)
Print margin specifications
Type
Top (leading edge)
Bottom (trailing edge)
Paper or transparency film
U.S. (Letter, Legal, Executive)
1.8 mm (0.07 inches)
6.7 mm (0.3 inches)
ISO (A4, A5) and JIS (B5)
6.7 mm (0.3 inches)
Envelopes
3.2 mm (0.13 inches)
6.7 mm (0.3 inches)
Cards
6.7 mm (0.3 inches)
Paper tray capacity
Type
Paper weight
Paper tray1
Output tray2
Plain paper
20 to 24 lb. (75 to 90 gsm)
100 (20 lb. paper)
50 (20 lb. paper)
Legal paper
100 (20 lb. paper)
50 (20 lb. paper)
Cards
110 lb. index max (200 gsm)
20
10
Envelopes
10
10
Transparency film
N/A
20
15 or fewer
Labels
N/A
20
10
4 x 6 inch (10 x 15 cm) Photo paper
145 lb. (236 gsm)
20
8.5 x 11 inch (216 x 279 mm) Photo paper
N/A
20
10
1 Maximum capacity.
2 Output tray capacity is affected by the type of paper and the amount of ink you are using. HP recommends emptying the output tray frequently.
Memory card specifications
  • Maximum recommended number of files on a memory card: 1,000
  • Maximum recommended individual file size: 12 megapixels maximum, 8 MB
  • Maximum recommended memory card size: 1 GB (solid state only)
Approaching any of the recommended maximums on a memory card might cause the performance of the HP Photosmart printer to be slower than expected.
Supported memory card types
  • CompactFlash Type 1 and II
  • Memory Stick
  • Memory Stick Duo
  • Memory Stick Pro
  • Secure Digital
    SDHC cards are not supported.
  • MultiMediaCard (MMC)
  • XD-Picture Card
Other memory cards, including Memory Stick Magic Gate Duo, Memory Stick Duo, and Secure Multimedia Card, are supported with the use of an adapter. See the instructions that came with your memory card for more information.
Scan specifications
  • Image editor included
  • Integrated OCR software automatically converts scanned text to editable text
  • Scan speeds vary according to the complexity of the document
  • Twain-compliant interface
  • Resolution: up to 1200 x 2400 dpi optical; 19200 dpi enhanced (software)
  • Color: 48-bit color, 8-bit grayscale (256 levels of gray)
  • Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
Physical specifications
Dimension
Measure
Height
40.2 cm (15.8 inches)
Width
46.5 cm (18.3 inches)
Depth
56.7 cm (22.3 inches)
4.5 kg (10 pounds)
Power specifications
  • Power consumption: 40 watts maximum
  • Input voltage: AC 100 to 240 V ~ 1 A 50–60 Hz, grounded
  • Output voltage: DC 32 Vdc===940 mA, 16 V===625 mA
Environmental specifications
  • Recommended operating temperature range: 15º to 32ºC (59º to 90ºF)
  • Allowable operating temperature range: 5º to 35ºC (41º to 95ºF)
  • Recommended operating humidity range: 15% to 80% RH non-condensing
  • Non-operating (Storage) temperature range: –20º to 50ºC (–4º to 122ºF)
In the presence of high electromagnetic fields it is possible the output from the HP All-in-One might be slightly distorted.
HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields.
