HP Photosmart C3100 All-in-One Printer Series Printer Specifications
This document outlines the product specifications for the HP Photosmart C3100 All-in-One series.
Figure : HP Photosmart C3100 All-in-One series
HP Photosmart C3100 All-in-One models
Printer model
Part number
HP Photosmart C3110
Q8163A
HP Photosmart C3125
Q8159A
HP Photosmart C3135
Q8158A
HP Photosmart C3140
Q8162A
Q8167A
HP Photosmart C3150
Q8161A
HP Photosmart C3170
Q8164B
HP Photosmart C3173
Q8164C
HP Photosmart C3175
Q8157C
HP Photosmart C3180
Q8160A
Q8160B
HP Photosmart C3183
Q8160C
HP Photosmart C3188
Q8160D
HP Photosmart C3190
Q8165B
HP Photosmart C3193
Q8165C
HP Photosmart C3194
Q8166B
Windows system requirements
Component
Express installation
Full installation
Explanation of installation type
The Express installation installs the basic software and the print drivers, and HP Photosmart Essential (not the full version of HP Photosmart Premier) software.
The Full installation installs the basic software and the print drivers, in addition to the HP Photosmart Premier software.
Windows 98 SE
Windows Me
Windows 2000 Professional with Service Pack 3 (SP3) or higher
Windows XP
Windows XP Media or Tablet edition
Windows Vista
Processor
Windows 2000 and XP: Any Intel Pentium II, Celeron, or compatible processor (Pentium III or higher recommended)
Windows Vista: A modern 800 MHz 32-bit (x86) or 64-bit (x64) Processor (1 GHz or higher recommended)
RAM
Windows 2000 and XP: 128 MB RAM (256 MB or higher recommended)
Windows Vista: 512 MB RAM (1 GB or higher recommended)
Free disk space
Windows 2000 and XP: 395 MB
Windows Vista: 1.2 GB
Includes Japanese language operating systems. Express installation does NOT install the Hagaki software.
Full-color scanning requires 50 MB more hard disk space.
Windows 2000 or XP: 855 MB
1.1 GB required on Japanese language operating systems. Full installation installs the Hagaki software. Hagaki software available for Japanese language only.
Video display
SVGA 800 x 600 monitor with 16-bit color or higher
CD drive
4x
Connectivity
USB
No network support
Microsoft Internet Explorer version
Internet Explorer 5.01 Service Pack 2 or higher
Microsoft Internet Explorer 6.0 SP1 or higher is required for Japanese and Finnish versions of Windows Me.
Macintosh system requirements
Component
Macintosh
OS X v 10.3, 10.4
Processor
G3 or greater
RAM
128 MB
Free disk space
500 MB
Video display
800 x 600, 16-bit or higher
CD drive
4x
Connectivity
USB 2.0 full speed, front and back ports (Mac OS X v 10.3 through v 10.4)
Cartridges
Printing specifications
The following tables contain printing specifications.
General
Category
Specification
Resolution
1200 x 1200 dots per inch (dpi) black; 4800 x 1200 optimized dpi color
Method
Drop-on-demand thermal inkjet
Language
PCL3 GUI
Print speed (varies by model)*
Up to 30 pages per minute (ppm) black; up to 24 ppm color
Duty cycle
3000 pages per month
*See www.hp.com/go/inkjetprinter for details.
Print speeds
Print mode
Type
Speed (ppm)1 after first page *
Speed (seconds) 4 x 6 inch borderless photo1 after first page*
Maximum dpi
Black and Color
up to 0.4
as fast as 140
Best
Black and Color
up to 2.3
as fast as 74
Normal
Black
up to 8.5
as fast as 54
Color
up to 5.3
as fast as 54
Fast Normal
Black
up to 11
as fast as 30
Color
up to 8
as fast as 30
Fast Draft
Black
up to 30
as fast as 30
Color
up to 24
as fast as 30
1Print speeds vary according to the complexity of the document.
Copying specifications
  • Digital image processing
  • Up to 9 copies from original (varies by model)
  • Up to 4800 x 1200 optimized dpi output using a scan resolution of 1200 x 1200ppi when copying onto premium photo media
  • Fit to page, pre-scan
Mode
Type
Scan resolution (dpi)1
Best
Black
up to 0.8
up to 600 x 1200
Color
up to 0.8
up to 600 x 1200
Normal
Black
up to 8.5
up to 300 x 300
Color
up to 5.1
up to 300 x 300
Fast
Black
up to 30
up to 300 x 300
Color
up to 24
up to 300 x 300
1Copy speeds vary according to the complexity of the document.
1Maximum at 400% scaling.
Scanning specifications
  • Image editor included
  • Integrated Optical Character Recognition (OCR) software automatically converts scanned text to editable text (if installed)
  • Scan speeds vary according to the complexity of the document
  • TWAIN compliant interface
  • Resolution: up to 1200 x 2400 dpi optical (varies by model); 19200 dpi enhanced (software)
  • Color: 48-bit color, 8-bit grayscale (256 levels of gray)
  • Maximum scan size from the glass: 216 x 297 mm (8.5 x 11.7 inches)
Memory card specifications
Review the following sections to learn about memory card specifications.
General recommendations
  • Maximum recommended number of files on a memory card: 1000
  • Maximum recommended individual file size: 12 megapixel or 8 MB
  • Maximum recommended memory card size: 1 GB (solid state only)
Approaching any of the recommended maximums on a memory card might cause the performance of the HP All-in-One to be slower than expected.
Supported memory card types
  • CompactFlash (I, II)
  • Memory Stick
  • Memory Stick Duo (with user-supplied adapter)
  • Memory Stick Pro
  • Secure Digital (SD)
    SDHC cards are not supported.
  • MultiMediaCard (MMC)
  • xD-Picture Card
Paper specifications
The following tables contain specifications regarding paper.
Paper tray capacities
Type
Paper weight
Paper tray1
Output tray2
Plain paper
75 to 90 gsm (20 to 24 pounds)
up to 100 (20 pound paper)
up to 50 (20 pound paper)
Legal paper
Cards
up to 200 gsm (110 pounds)
up to 20
up to 10
Envelopes
up to 10
up to 10
Transparency film
N/A
up to 20
15 or fewer
Labels
N/A
up to 20
up to 10
102 x 152 mm (4 x 6 inches) photo paper
up to 236 gsm (145 pounds)
up to 20
up to 15
216 x 280 mm (8.5 x 11 inches) photo paper
N/A
up to 20
up to 10
1 Maximum capacity.
2 The amount of ink and type of paper you use for a print job affects output tray capacity. HP recommends emptying the output tray frequently.
Paper sizes
Type
Size
Paper
Letter: 216 x 280 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm (8.3 x 11.7 inches)
Envelopes
U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. 9: 98 x 225 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency film
Letter: 216 x 279 mm (8.5 x 11 inches)
Premium photo paper
Cards
A6: 105 x 148.5 mm (4.1 x 5.8 inches)
Index card: 76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
Labels
Custom
102 x 152 mm to 216 x 356 mm (4 x 6 inches to 8.5 x 14 inches)
Print margin specifications
Paper size
Top (leading edge)
Bottom (trailing edge)
Left and Right margins
US Letter
US Legal
US Executive
3 mm (0.12 inches)
3 mm (0.12 inches)
7.1 mm (0.28 inches)
ISO A4
ISO A5
JIS B5
3 mm (0.12 inches)
3 mm (0.12 inches)
Envelopes
3 mm (0.12 inches)
3 mm (0.12 inches)
7.1 mm (0.28 inch)
Cards
3 mm (0.12 inches)
3 mm (0.12 inches)
7.1 mm (0.28 inch)
Physical specifications
Dimension
Measurement
Height
162 mm (6.4 inches)
Width
434 mm (17.1 inches)
Depth (with output tray extended)
381 mm (15 inches)
7.66 kilograms (16.9 pounds)
Power specifications
Category
Specification
Power consumption
25 watt maximum
Input voltage
100 to 240 volts, alternating current
Input current
1 A
Input frequency
50 to 60 Hz, grounded
Output voltage
16 to 32 volts, direct current
Output current
530 to 560 mA
Environmental specifications
HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields.
Recommended operating conditions
Specification
Temperature
15 to 32 degrees C (59 to 90 degrees F)
Humidity
15 to 80 percent relative humidity non-condensing
Maximum operating conditions
Specification
Temperature
5 to 35 degrees C (41 to 95 degrees F)
Humidity
Storage conditions
Specification
Temperature
-20 to 50 degrees C (-4 to 122 degrees F)
Humidity
Regulatory specifications
The product requirements from regulatory agencies in your country/region. For a complete listing of regulatory notices, see the on-screen Help.
Exposure to radio frequency radiation
In the presence of high electromagnetic fields, it is possible that the output from the HP Photosmart might be slightly distorted.
Regulatory model identification number
For regulatory identification purposes, your product is assigned a Regulatory Model Number. The Regulatory Model Number for your product is SDGOB-0603. This regulatory number should not be confused with the marketing name (HP Photosmart C3100 All-in-One series, etc.) or product numbers (Q8150A, etc.).
