    Apache Log4j Update
Printer Specifications for HP Deskjet F300 All-in-One Printers
Figure : HP Deskjet F300 Series All-in-One
Model numbers
Printer model
Part number
HP Deskjet F310
Q8138A
HP Deskjet F325
Q8135A
HP Deskjet F335
Q8137A
HP Deskjet F340
Q8139A
HP Deskjet F350
Q8136A
HP Deskjet F370
Q8140A
HP Deskjet F375
Q8145A
HP Deskjet F378
Q8141A
HP Deskjet F380
Q8134A
HP Deskjet F385
Q8145A
HP Deskjet F388
Q8143A
HP Deskjet F390
Q8142A
HP Deskjet F394
Q8144A
System requirements
Windows system requirements
Component
Express installation
Full installation
Explanation of installation type
The Express installation installs the basic software and drivers, and HP Photosmart Essential (not the full version of HP Photosmart Premier) software.
The Full installation installs the basic software and drivers, as well as the HP Photosmart Premier software.
Microsoft Windows 98, 98 SE, Me, 2000 Professional Service Pack 3 or higher, XP, XP Media or Tablet edition (does not support Windows 95, 3.1, NT 4.0, DOS, 2003 Server, or 64-bit).
Microsoft Windows 2000 Professional Service Pack 3 or higher, XP, XP Media or Tablet edition (does not support Windows 95, 3.1, NT 4.0, DOS, 2003 Server, or 64-bit).
Processor
Any Intel Pentium II, Celeron, or compatible processor (Pentium III or higher recommended)
RAM
128 MB RAM for 98, 98 SE, Me, 2000 and XP (256 MB or higher recommended for all operating systems).
128 MB RAM for 2000 and XP (256 MB or higher recommended for all operating systems).
Free disk space
395 MB available hard disk space for software installation.
Includes Japanese language operating systems. Express installation does NOT install the Hagaki software.
Full-color scanning requires an additional 50 MB hard disk space.
855 MB available hard disk space for software installation.
1.1 GB required on Japanese language operating systems. Full installation installs the Hagaki software. Hagaki software available for Japanese language only.
Video display
SVGA 800 x 600 monitor with 16-bit color or higher
CD-ROM drive
4x
4x
Connectivity
USB: Windows 98, 2000 Professional, Me, XP Home, and XP Professional
USB: Windows 2000 Professional, XP Home, and XP Professional
Internet Explorer version
Internet Explorer 5.01 Service Pack 2 or higher is required.
Microsoft Internet Explorer 6.0 SP1 or higher is required for Japanese and Finnish versions of Windows Me.
Macintosh system requirements
Component
Macintosh
OS X v 10.3, 10.4
Processor
G3 or greater
RAM
128 MB
Free disk space
500 MB
Video display
800 x 600, 16-bit or higher
CD-ROM drive
4x
Connectivity
USB 2.0 full speed, front and back ports
PictBridge: using front camera port
Printing specifications
General
Category
Specification
Resolution
Black: Up to 600 x 600 dots per inch (dpi)
Color: Up to 4800 x 1200 optimized dpi
Method
Drop-on-demand thermal inkjet
Language
Lightweight Imaging Device Interface Language (LIDIL)
Duty cycle
700 printed pages per month
Print speed
Print speeds vary according to the complexity of the document
Print resolution
Mode
Type
Scan resolution (dpi)1
Maximum dpi
Black
up to 4800 x 1200 optimized
Color
up to 4800 x 1200 optimized1
Best
Black
up to 1200 x 1200
Color
1200 x 1200 up to 4800 dpi optimized1
Normal
Black
up to 600 x 600
Color
up to 600 x 600
Fast Normal
Black
up to 300 x 300
Color
up to 300 x 300
Fast Draft
Black
up to 300 x 300
Color
up to 300 x 300
1Up to 4800 x 1200 optimized dpi color printing on premium photo papers, 1200 x 1200 input dpi.
Copying specifications
  • Digital image processing
  • Up to 9 copies from original (varies by model)
  • Fit to page
  • Copy speeds vary according to the complexity of the document
Mode
Type
Print resolution (dpi)
Best
Black
up to 600 x 600
up to 600 x 2400
Color
up to 1200 x 12002
up to 600 x 2400
Fast
Black
up to 300 x 1200
up to 600 x 1200
Color
up to 600 x 300
up to 600 x 1200
1Maximum at 400 percent scaling.
2On photo paper or premium paper.
Scanning specifications
  • Image editor included
  • Integrated Optical Character Recognition (OCR) software automatically converts scanned text to editable text
  • TWAIN compliant interface
  • Resolution: up to 1200 x 2400 dpi optical; up to 19,200 dpi enhanced (varies by model)
  • Color: 48-bit color, 8-bit grayscale (256 levels of gray)
  • Maximum scan size from the glass: 216 x 297 mm (8.5 x 11.7 inches)
  • Scan speeds vary according to the complexity of the document
Physical specifications
Dimension
Measure
Height
170 mm (7.0 inches)
Width
440 mm (16.8 inches)
Depth
259 mm (10.2 inches)
4.5 kilograms (10 pounds)
Paper specifications
Paper tray capacities
Type
Paper weight
Paper tray1
Output tray2
Plain paper
75 to 90 gsm (20 to 24 pounds)
up to 100 (20 pound paper)
up to 50 (20 pound paper)
Legal paper
Cards
up to 200 gsm (110 pounds)
up to 20
up to 10
Envelopes
up to 10
up to 10
Transparency film
N/A
up to 20
up to 15
Labels
N/A
up to 20
up to 10
102 x 152 mm (4 x 6 inches) photo paper
up to 236 gsm (145 pounds)
up to 20
up to 15
216 x 279 mm (8.5 x 11 inches) photo paper
N/A
up to 20
up to 10
1 Maximum capacity.
2 Output tray capacity is affected by the type of paper and the amount of ink you are using. HP recommends emptying the output tray frequently.
Paper sizes
Type
Size
Paper
Letter: 216 x 280 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm (8.3 x 11.7 inches)
A5: 148 x 210 mm (5.8 x 8.3 inches)
Executive: 184 x 267 mm (7.25 x 10.5 inches)
JIS (B5): 182 x 257 mm (7.2 x 10.1 inches)
Envelopes
U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency film
Letter: 216 x 279 mm (8.5 x 11 inches)
Premium photo paper
102 x 152 mm (4 x 6 inches), with tear-off tab
127 x 178 mm (5 x 7 inches)
130 x 180 mm (5.12 x 7.09 inches)
203 x 254 mm (8 x 10 inches)
A6: 105 x 148.5 mm (4.13 x 5.85 inches)
Hagaki: 100 x 148 mm (3.94 x 5.83 inches)
Cards
76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
Labels
Custom
76 x 127 mm to 216 x 356 mm (3 x 5 inches to 8.5 x 14 inches)
Print margin specifications
Paper size
Top (leading edge)
Bottom (trailing edge)1
Left and Right margins
US Letter
US Legal
US Executive
1.8 mm (0.07 inches)
12.7 mm (0.5 inches)
6.4 mm (0.25 inches)
ISO A4
ISO A5
JIS B5
13.7 mm (0.54 inches)
3.3 mm (0.13 inches)
Envelopes
13.5 mm (0.53 inches)
Cards
1This margin is not compatible; however, the total writing area is compatible. The writing area is offset from center by 5.4 mm (0.21 inches), which causes asymmetric top and bottom margins.
Power specifications
Category
Specification
Power consumption
80 watt maximum
Input voltage
100 to 240 volts, alternating current
Input current
1 A
Input frequency
50 to 60 Hz, grounded
Output voltage
15 to 32 volts, direct current
Output current
530 to 560 mA
Environmental specifications
In the presence of high electromagnetic fields it is possible that the output from the HP Officejet might be slightly distorted.
HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields.
Recommended operating conditions
Specification
Temperature
15 to 32 degrees C (59 to 90 degrees F)
Humidity
15 to 80 percent relative humidity non-condensing
Maximum operating conditions
Specification
Temperature
5 to 35 degrees C (41 to 95 degrees F)
Humidity
Storage conditions
Specification
Temperature
-20 to 50 degrees C (-4 to 122 degrees F)
Humidity
