    Fix HP Printer issue on macOS
HP Scanjet 8270 Scanner - Scan Two-Sided Originals
Scan two-sided documents using the automatic document feeder (ADF).
Scanning two-sided documents
Before placing an original in the ADF, check for and remove curls, wrinkles, staples, paper clips, and any other attached material. Make sure that sheets are not stuck together.
  1. Place a stack of similarly sized pages face-up in the input tray of the ADF, with the first page on top. The top of the page should point towards the document feeder.
    Figure : Loading originals in the ADF
  2. Adjust the paper guides to center the stack.
  3. Slide the Duplex switch located near the ADF to the left. This puts the scanner in Duplex mode.
  4. Open HP Solution Center.
    1. Click Start.
    2. Click Programs.
    3. Click HP.
    4. Click HP Solution Center.
  5. Click Scan Document. The HP Scanning dialog box displays.
  6. Click Scan.
  7. After the scan is complete, click Done. HP Solution Center sends the scanned file to the specified location.
