Printer Specifications for HP Photosmart Pro B9180 and B9180gp Photo Printers
Figure : HP Photosmart Pro B9180 Printer
Model numbers
Printer model number
Availability
Q5736A
United States, Asia Pacific, Europe, Latin America
Q5738A
Canada
HP Photosmart Pro B9180gp
Q5743A
Features
  • Scalable Printing Technology with four printheads and eight ink cartridges for high-quality images.
  • Fade-resistant photos with bright colors when used in conjunction with the newly-designed HP Advanced Photo Paper.
  • Print in a range of sizes, from 7.6 x 13 cm to 32 x 48 cm (3 x 5 inches to 13 x 19 inches).
  • Specialty media tray and straight-through paper path for printing on rigid or thick media such as card stock.
  • Built-in Ethernet network connectivity.
  • HP Photosmart Pro Print plug-in for Adobe Photoshop for high quality, professional prints.
System requirements
Component
Windows minimum
Macintosh minimum
Operating System
Windows 2000 Professional, XP Home, and XP Professional, and XP Professional 64
Mac OS X v. 10.3x and 10.4x
Processor
Intel Pentium II (or equivalent) or higher
G3 or greater
Minimum RAM
64 MB (128 MB recommended)
128 MB
Free disk space
600 MB (2GB recommended)
150 MB
Video display
800 x 600, 16-bit or higher
CD-ROM drive
4x
4x
Browser
Microsoft Internet Explorer 5.5 or later
None
Network support
Network support
Windows 2000 Professional, XP Home, XP Professional, and XP Professional 64
Mac OS X 10.3.x and 10.4.x
Ink cartridges and printheads
These cartridges contain pigment-based ink.
Ink cartridges
Printheads
HP 38 Matte Black Pigment ink cartridge
HP 70 Photo Black/Light Gray printhead
HP 38 Light Gray Pigment ink cartridge
HP 70 Matte Black/Cyan printhead
HP 38 Photo Black Pigment ink cartridge
HP 70 Magenta/Yellow printhead
HP 38 Cyan Pigment ink cartridge
HP 70 Light Cyan/Light Magenta printhead
HP 38 Magenta Pigment ink cartridge
HP 38 Yellow Pigment ink cartridge
HP 38 Light Magenta Pigment ink cartridge
HP 38 Light Cyan Pigment ink cartridge
Print specifications
Print speed
  • 27 ppm black text
  • 25 ppm mixed graphics
  • 10 seconds - 4 x 6 with border printed at the photo draft setting
Duty cycle
1000 pages per month.
Print resolution
4800 dpi x 1200 optimized dpi
Print margins
Minimum printing margins.
Paper type
Top/Bottom margin
Left/Right margin
Rigid media
14 mm (0.55 inches)
3 mm (0.12 inches)
All other media (borderless printing)
0.0 mm (0.0 inches)
0.0 mm (0.0 inches)
Color Management Strategy
  • HP Photosmart Pro Print plug-in for Adobe Photoshop versions PS 7, CS1, and CS2
  • Application-based color management
  • Printer-based color management
Connectivity
Built-in connectivity
  • Ethernet 802.3
  • Universal Serial Bus (USB) 2.0 High Speed.1 HP recommends that the USB cable be less than 3 meters (10 feet) long.
1 Standard USB cable that can be purchased at most retail outlets.
Paper handling
In tray, out tray, and specialty tray capacity
Paper type
Main tray
Out tray
Specialty tray
Plain paper
200 sheets
50 sheets
1 sheet of any media up to 1.5 mm thick
Photo paper
60 sheets
20 sheets
Envelopes
50 envelopes
10 envelopes
Cards
20 to 40 depending on thickness
10 cards
Labels
30 sheets
10 sheets
Paper trays and supported paper sizes
Tray
Specification
Main tray
7.6 x 12.7 cm to 33 x 48.3 cm (3 x 5 inches to 13 x 19 inches)
Output tray
All supported sizes
Media specifications
Dimension
Size
Recommended maximum length
Recommended minimum length
483 mm (19 in)
33 mm (3 inches)
Recommended maximum width
Recommended minimum width
330 mm (13 in)
48.3 mm (3 x 5 inches)
Recommended maximum thickness
1.5mm
Recommended plain paper weight
60 to 90 g/m2 (16 to 24 pounds)
Recommended maximum photo paper weight
280 g/m2 (applies to the main tray only)
Supported media types
Media types
Paper (photo, plain, and inkjet)
Envelopes
Labels
Cards (index, greeting, Hagaki, A6, L-size)
Iron-on transfers
Supported paper sizes
76 x 127 mm to 330 x 483 mm (3 x 5 inches to 13 x 19 inches), including the following:
Category
Paper type
Size
North America
Letter
216 x 279 mm (8.5 x 11 inches)
Legal
216 x 356 mm (8.5 x 14 inches)
Executive
184 x 267 mm (7.3 x 10.5 inches)
Tabloid
279 x 431 mm (11.00 x 17.00 inches)
Metric
10 x 15 cm (with or without tab)
100 x 150 mm (3.9 x 5.9 inches)
Panorama
100 x 300 mm (3.9 x 11.8 inches)
13 x 18 cm
130 x 180 mm (5.1 x 7 inches)
A3
297 × 420 mm (11.69 x 16.54 inches)
A4
210 x 297 mm (8.3 x 11.7 inches)
A5
148 x 210 mm (5.9 x 8.3 inches)
A6
105 x 148 (4.13 x 5.83 inches)
B4
250 × 353 (9.8 x 13.9 inches)
B5
182 x 257 mm (7.2 x 10.1 inches)
Envelopes
Number 10
105 x 241 mm (4.1 x 9.5 inches)
Invitation A2
111 x 146 mm (4.4 x 5.8 inches)
C6
114 x 162 mm (4.5 x 6.4 inches)
DL
110 x 220 mm (4.3 x 8.7 inches)
Japan
L
89 x 127 mm (3.5 x 5 inches)
2L
178 x 127 mm (7 x 5 inches)
Hagaki
100 x 148 mm (3.9 x 5.8 inches)
Ofuku Hagaki
200 x 148 mm (7.9 x 5.8 inches)
Imperial
12 x 12 inches
305 x 305 mm (12 x 12 inches)
13 x 19 inches
330 x 483 mm
Index
76 x 127 mm (3 x 5 inches)
102 x 152 mm (4 x 6 inches)
127 x 203 mm (5 x 8 inches)
102 x 152 mm (4 x 6 inches) with or without tab
127 x 178 mm (5 x 7 inches)
203 x 254 mm (8 x 10 inches)
279 x 355 mm (11 x 14 inches)
Panorama 4 x 10 inches
101 x 254 (4 x 10 inches)
Panorama 4 x 11 inches
101 x 279 mm (4 x 11 inches)
Panorama 4 x 12 inches
101 x 305 mm (4 x 12 inches)
Physical specifications
The dimensions listed are for the printer with the paper tray extended.
Category
Specification
Width
643 mm (25.3 inches)
Height
203 mm (8 inches)
Depth
398 mm (15.7 inches)
Net weight (without cartridges)
16.95 kg (37.37 pounds)
Power cord specifications
Model number
Country/region
8121-0740
North America
8121-0731
Korea, Europe (except those listed below)
8121-0731, 8121-0733
Denmark, Sweden, Norway, Finland
8121-0731, 8121-0739, 8121-0740
CIS, Russia, Middle East, Africa (except South Africa)
8121-0837
Australia
8121-0737 + 8121-1004
Israel, South Africa
8121-0738
Switzerland
Power consumption
State
Specification
Printing
29 watts
Idle
6 watts
Off
5 watts
Operating environment
Operating conditions
Maximum operating conditions
Specification
Temperature
41 to 104 degrees F (5 to 40 degrees C)
Humidity
20 to 80 percent relative humidity (non-condensing)
Operating conditions for best print quality
Optimal operating conditions
Specification
Temperature
59 to 95 degrees F (15 to 35 degrees C)
Humidity
Region
Printer
Print cartridges
Worldwide (Note that regional differences may apply to warranty specifications
One year
90 days
End of life or date stamped
Environmental specifications
Hewlett-Packard Company is committed to providing quality products in an environmentally sound manner. This printer has been designed with several attributes to minimize impact on HP's environment. For more information, go to HP's Commitment to the Environment Web site (in English).
Material safety data sheets
Material Safety Data Sheets (MSDS) can be obtained from the HP Web site (in English).
Recycling program
HP offers an increasing number of product return and recycling programs in many countries/regions, and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. More information on www.hp.com/go/recycle can be obtained from the HP Web site (in English).
Recycled paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309. Plastic parts over 24 grams (0.88 ounces) are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the printer's life.
Ozone production
This product generates no appreciable ozone gas (O3).
