HP Compaq nx9420 Notebook PC Product Specifications
Product description
Designed for power users who need extreme performance and widescreen functionality combined with mobile convenience
Product Features
Feature
Processors
  • Intel Core Duo processor T2600* (2.16-GHz, 667-MHz FSB, 2-MB L2 cache)
  • Intel Core Duo processor T2500* (2.00-GHz, 667-MHz FSB, 2-MB L2 cache)
  • Intel Core Duo processor T2400* (1.83-GHz, 667-MHz FSB, 2-MB L2 cache)
  • Intel Core Duo processor T2300* (1.66-GHz, 667-MHz FSB, 2-MB L2 cache)
* Intel's numbering is not a measurement of higher performance. Processor speed denotes maximum performance mode; processors will run at approximately 1 GHz in battery optimization mode.
Mobile Intel 945PM Express Chipset with 667-MHz front side bus
Graphics
ATI Mobility Radeon X1600 graphics controller with 256 MB of discrete video memory
Display Internal
  • 17.0-inch WXGA+ display with 1440 x 900 resolution and 16M colors
  • 17.0-inch WSXGA+ wide viewing angle display with 1680 x 1050 resolution and 16M colors
  • 17.0-inch WSXGA+ wide viewing angle BrightView display with 1680 x 1050 resolution and 16M colors
  • 17.0-inch WUXGA wide viewing angle display with 1920 x 1200 resolution and 16M colors
  • Ambient light sensor
Display External
  • Up to 32-bit per pixel color depth
  • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
  • DVI port in optional HP Docking Station (sold separately) supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Memory Standard
  • 256-MB, 512-MB, 1024-MB 533-MHz DDR2 SDRAM SODIMMs
  • 256-MB, 512-MB, 1024-MB or 2048-MB 667-MHz DDR2 SDRAM SODIMMs
  • Two SODIMM slots supporting dual channel memory
Memory Maximum
Upgradeable to 4096-MB maximum (2048-MB SODIMM in slots 1 and 2)
Memory Dual-channel
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed. Above 3-GB, all memory may not be available due to system resource requirements.
Communications
  • Integrated Broadcom NetXtreme Gigabit Ethernet PCI Express Controller (10/100/1000 NIC*) with HP Smart Power NIC technology
  • 56K V.92 modem** with digital line guard
* The term "10/100/1000" or "Gigabit" Ethernet indicates compliance with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/sec. For high speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
** Designed for downloads from 56K modem compliant sources. Maximum achievable download transmission rates currently do not reach 56 KB/s, and will vary with line conditions. Modem availability is subject to country regulatory approval.
Wireless Devices
Support for a broad range of secure, integrated wireless LAN options featuring support for the latest industry standards. Integrated Bluetooth is also an option (factory configurable only) and can be combined with any one of the supported wireless LAN options.
All integrated wireless LAN options
Wi-Fi certified
Cisco Compatible Extensions support (Version 4.0)
Wired Equivalent Privacy (WEP) support up to 128-bit keys
Wi-Fi Protected Access (WPA) and WPA2 support
802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP
Advanced Encryption Standard (AES) support
WiFi Certified for WPA2, WMM
Dual antennas integrated in the display enclosure
Intel PRO/Wireless 3945ABG Network Connection
Intel Centrino mobile technology
Integrated support for 802.11a, b and g
Up to 54-mbps data rate
Intel PRO/Wireless 3945BG Network Connection
Integrated support for 802.11 b and g
Broadcom 4311AG WiFi Adapter
Broadcom 4311BG WiFi Adapter
HP Integrated Module with Bluetooth 2.0 Wireless Technology
Bluetooth Specification v2.0 compliant Works with a wide range of Bluetooth devices
Keyboard
The 101/102-key compatible keyboard features an industry standard, full-width layout with desktop keyboard features such as isolated inverted-T cursor control keys, left and right control and alt keys, and 12 function keys. Other features include a full numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 19.05 mm x 19.05 mm key pitch (center-to-center spacing), 3.0 mm stroke, comfort-dished keycaps, and bright key legends for improved visibility in low light conditions.
One-Touch Productivity Buttons
Provide one-touch access to the following features: HP Info Center, Wireless On/Off, Presentation Mode, Volume down, Volume up, Volume Mute, and Calculator Launch.
Pointing Device
Touchpad with scroll zone, two soft-touch pick buttons
Expansion Card Slots
One Type I/II PC Card slot Supports 32-bit CardBus and 16-bit PC Cards
One Integrated Smart Card Reader Compatible with ISO 7816 compliant Smart Cards PC/SC interface support
Media Slots
7-in-1 Media Reader Supports SD (Secure Digital), MMC (MultiMedia Card), Memory Stick, Memory Stick Pro, Memory Stick Duo*, Smart Media, xD-Picture card
Hard Drives
60-, 80-, 100-GB 5400 rpm SMART SATA
80-, 100-GB 7200 rpm SMART SATA
These hard drives are customer removable and will withstand multiple insertion/removal cycles. Up to 8GB is reserved for the system recovery software.
HP Mobile Data Protection System 3D
Hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration.
Fixed Optical Drives
DVD-ROM DVD/CD-RW
Combo DVD+/-RW SuperMulti with Double Layer LightScribe
DVD+/-RW with Double Layer
PC Card Slot: One – Type I/II
Smart Card Reader: One
External Monitor: One – VGA
External Microphone: One
Headphone/Line out: One
Power Connector: One
RJ-11 (Modem): One
RJ-45 (NIC): One
Ambient Light Sensor: One
IEEE 1394 Port (4-pin): One
S-Video TV Out: One (Support for NTSC/PAL)
USB 2.0: Four
Docking Connector: One
Travel Battery Connector: One
LED Status Indicators: Twelve
Audio
ADI High Definition CODEC
Integrated 16-bit Sound Blaster Pro compatible audio
Integrated stereo speakers
Integrated directional microphone
External volume up, volume down, and mute buttons
Stereo headphone/line out
Stereo microphone in
Power Supply
External 90-watt AC adapter, 6-foot (1.8-meter) power cord included. Total length including External AC adapter is 12 feet (3.66 meter). HP Fast Charge technology
Primary Battery
69Wh 8-cell high capacity Lithium-Ion (up to Up to 4 hours battery life)
Optional HP 8-Cell Extended Life Battery
52Wh 8-cell high capacity Lithium-Ion (Up to Up to 7 hours and 30 minutes battery life)
Optional HP 12-Cell Ultra-Capacity Battery
95Wh 12-cell high capacity Lithium-Ion (Up to Up to 10 hours battery life)
Service and Support
HP Services includes a one- year standard parts and labor warranty, pick-up or carry-in, and toll-free 7 x 24 hardware technical phone support (depending on model). On-site service and warranty upgrades are also available.
Certain restrictions and exclusions apply.
Hard Drive Specifications
100 GB 7200 rpm
Item
Specification
Drive Weight
113 g (0.25 lb)
Capacity
100 GB
Height
9.5 mm (0.37 inches)
Width
70 mm (2.75 inches)
Interface
ATA-6
Transfer Rate
Synchronous (maximum)
100 MB/s (Drive Capability)
Seek Time (typical reads, including settling)
Single Track
1 ms
Average
10 ms
Maximum
18 ms
Rotational Speed
7200 rpm
Logical Blocks
195,371,568
Operating Temperature
41° degrees to 131° degrees F (5° degrees to 55° degrees C)
Features
ATA Security
80 GB 7200 rpm
Item
Specification
Drive Weight
113 g (0.25 lb)
Capacity
80 GB
Height
Width
70 mm (2.75 inches)
Interface
ATA-6
Transfer Rate
Single Track
1 ms
Average
10 ms
Maximum
18 ms
Rotational Speed
7200 rpm
Logical Blocks
156,301,488
Features
ATA Security
100 GB 5400 rpm
Item
Specification
Drive Weight
100 GB 5400 rpm
Capacity
100 GB
Height
Width
70 mm (2.75 inches)
Interface
ATA-6
Transfer Rate
Single Track
3 ms
Average
13 ms
Maximum
24 ms
Rotational Speed
5400 rpm
Logical Blocks
195,371,568
Features
ATA Security
80 GB 5400 rpm
Item
Specification
Drive Weight
99 g (0.22 lb)
Capacity
80 GB
Height
Width
70 mm (2.75 inches)
Interface
ATA-6
Transfer Rate
Single Track
3 ms
Average
13 ms
Maximum
24 ms
Rotational Speed
5400 rpm
Logical Blocks
156,301,488
Features
ATA Security
60 GB 5400 rpm
Item
Specification
Drive Weight
99 g (0.22 lb)
Capacity
60 GB
Height
Width
70 mm (2.75 inches)
Interface
ATA-6
Transfer Rate
Single Track
3 ms
Average
13 ms
Maximum
24 ms
Rotational Speed
5400 rpm
Logical Blocks
117,210,240
Features
ATA Security
Removable Storage Drive Specifications
DVD-ROM Drive
Item
Specification
Access Times
Random
  • < 116 ms CD
  • < 125 ms DVD
Max Data Transfer Rate
24X CD-ROM
3,600 KB/s
8X-DVD
10,800 KB/s
Transfer Mode
Multiword DMA Mode 2
Interface
EIDE
Supported Media (read)
CD-DA, CD+(E)G, CD-MIDI, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW
Supported Media (write)
None
Max Media Capacity (read)
4.7 GB
Transport
Tray Loading
DVD/CD-RW Combo Drive
Item
Specification
Access Times
Random
  • < 110 ms CD
  • < 130 ms DVD
24X CD-ROM
3,600 KB/s
8X DVD
10,800 KB/s
24X CD-R
3,600 KB/s
24X CD-RW
3,600 KB/s
Transfer Mode
Interface
EIDE
CD-R, CD-RW
8.5 GB
Max Media Capacity (write)
700 MB
Transport
Tray loading
LightScribe DVD+/-RW Drive with Double Layer
Item
Specification
Access Times
Random
  • < 175 ms CD
  • < 230 ms DVD
24X CD-ROM
3,600 KB/s
8X DVD
10,800 KB/s
24X CD-R
3,600 KB/s
10X CD-RW
1,500 KB/s
8X DVD+R
10,800 KB/s
4X DVD+RW
5,400 KB/s
8X DVD-R
10,800 KB/s
4X DVD-RW
5,400 KB/s
2.4X DVD+R(9)
2,700 KB/s
Transfer Mode
Interface
EIDE
CD-DA, CD+(E)G, CD-MIDI, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, LightScribe
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW
8.5 GB
8.5 GB
Transport
Tray Loading
DVD+/-RW SuperMulti Drive with Double Layer
Item
Specification
Access Times
Random
  • < 175 ms CD
  • < 230 ms DVD
24X CD-ROM
3,600 KB/s
8X DVD
10,800 KB/s
24X CD-R
3,600 KB/s
10X CD-RW
1,500 KB/s
8X DVD+R
10,800 KB/s
4X DVD+RW
5,400 KB/s
8X DVD-R
10,800 KB/s
4X DVD-RW
5,400 KB/s
2.4X DVD+R(9)
2,700 KB/s
5X DVD-RAM
6,750 KB/s
Transfer Mode
Multiword DMA Mode
Interface
EIDE
CD-DA, CD+(E)G, CD-MIDI, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW. DVD-RAM
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM
8.5 GB
8.5 GB
Transport
Tray Loading
HP Biometric Fingerprint Sensor
Item
Specification
Mobile Voltage Operation
3.0 Volts – 3.6 Volts Single Supply
32° degrees – 158° degrees F (0° degrees – 70° degrees C)
Current Consumption @ 3.3 Volts
  • Less than 70 mA peak imaging and scrolling
  • Less than 25 mA hardware finger detection
  • Advanced Power Management
High-Rate Image Capture
Up to 240 image frames /sec
ESD Resistance
IEC 61000-4-2 Level 4 (±15KV)
Detection Matrix
  • 192 x 16 Pixels
  • 9.7mm x 0.81mm
  • 500 ppi High-Resolution Images
System Specifications
Item
Specification
Processor
  • Intel Core Duo processor T26001 (2.16 GHz, 667 MHz FSB, 2 MB L2 cache)
  • Intel Core Duo processor T25001 (2.00 GHz, 667 MHz FSB, 2 MB L2 cache)
  • Intel Core Duo processor T24001 (1.83 GHz, 667 MHz FSB, 2 MB L2 cache)
  • Intel Core Duo processor T23001 (1.66 GHz, 667 MHz FSB, 2 MB L2 cache)
Note 1: Intel's numbering is not a measurement of higher performance.
Operating System
Preinstalled
  • Genuine Microsoft Windows XP Professional SP2
  • Genuine Microsoft Windows XP Home Edition SP2
  • FreeDOS
Supported
Microsoft Windows 2000 (drivers downloadable from HP website)
Certified
Novell Linux Desktop 9
Mobile Intel 945PM Express Chipset with 667 MHz front side bus
Graphics
Internal
  • 17.0 inch WXGA+ display with 1440 x 900 resolution and 16M colors
  • 17.0 inch WSXGA+ wide viewing angle display with 1680 x 1050 resolution and 16M colors
  • 17.0 inch WSXGA+ wide viewing angle BrightView display with 1680 x 1050 resolution and 16M colors
  • 17.0 inch WUXGA wide viewing angle display with 1920 x 1200 resolution and 16M colors
External
  • Up to 32 bit per pixel color depth
Memory
Standard
  • 256 MB, 512 MB, 1024 MB 533 MHz DDR2 SDRAM SODIMMs
  • 256 MB, 512 MB, 1024 MB or 2048 MB 667 MHz DDR2 SDRAM SODIMMs
Maximum
Upgradeable to 4096 MB maximum (2048 MB SODIMM in slots 1 and 2)
Dual-channel
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed. Above 3 GB, all memory may not be available due to system resource requirements.
Communications
  • Integrated Broadcom NetXtreme Gigabit Ethernet PCI Express Controller (10/100/1000 NIC2) with HP Smart Power NIC technology
  • 56K V.92 modem3 with digital line guard
Note 2: The term '10/100/1000' or 'Gigabit' Ethernet indicates compliance with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/sec. For high speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Note 3: Designed for downloads from 56K modem compliant sources. Maximum achievable download transmission rates currently do not reach 56 KB/s, and will vary with line conditions. Modem availability is subject to country regulatory approval.
Wireless Devices
  • Wi-Fi certified
  • Cisco Compatible Extensions support (Version 4.0)
  • Wired Equivalent Privacy (WEP) support upto 128-bit keys
  • Wi-Fi Protected Access (WPA) and WPA2 support
  • 802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP
  • Advanced Encryption Standard (AES) support
  • WiFi Certified for WPA2, WMM
  • Dual antennas integrated in the display enclosure
  • Intel Centrino mobile technology
  • Integrated support for 802.11a, b and g
  • Up to 54 mbps data rate
  • Integrated support for 802.11 b and g
  • Bluetooth Specification v2.0 compliant
  • Works with a wide range of Bluetooth devices
Keyboard
Pointing Device
Touchpad with scroll zone, two soft-touch pick buttons.
Supports 32-bit CardBus and 16-bit PC Cards.
Compatible with ISO 7816 compliant Smart Cards PC/SC interface support.
Media Slots
7-in-1 Media Reader
Supports SD (Secure Digital), MMC (MultiMedia Card), Memory Stick, Memory Stick Pro, Memory Stick Duo4, Smart Media, xD-Picture card.
Note 4: Memory Stick Duo Adapters are required and sold separately. Inserting a Memory Stick Duo Card directly into your notebook could damage the memory card and/or notebook.
Storage
Hard Drives
  • 60 GB, 80 GB, 100 GB 5400 rpm SMART SATA
  • 80 GB, 100 GB 7200 rpm SMART SATA
These hard drives are customer removable and will withstand multiple insertion/removal cycles. Up to 8 GB is reserved for the system recovery software.
  • DVD-ROM
  • DVD/CD-RW Combo
  • DVD+/-RW SuperMulti with Double Layer
  • LightScribe DVD+/-RW with Double Layer
Interfaces
PC Card Slot
One – Type I/II
Smart Card Reader
One
External Monitor
One – VGA
External Microphone
One
Headphone/Line out
One
Power Connector
One
RJ-11 (Modem)
One
RJ-45 (NIC)
One
One
One
S-Video TV Out
USB 2.0
Four
Docking Connector
One
One
Twelve
Audio
  • ADI High Definition CODEC
  • Integrated 16-bit Sound Blaster Pro compatible audio
  • Integrated stereo speakers
  • Integrated directional microphone
  • External volume up, volume down, and mute buttons
  • Stereo headphone/line out
  • Stereo microphone in
Security
Standard Features
HP ProtectTools Security Manager
Configuration Control Hardware
Memory Change Alert
Ownership Tag
Setup Password
Power-On Password
HP Drivelock
TPM Enhanced Drivelock
HP Disk Sanitizer
Enabled for PC Smart Card
Kensington Lock Slot
  • Compatible with ISO 7816 compliant Smart Cards
  • PC/SC interface support
TPM Embedded Security Chip
  • Designed to the Trusted Computing Group (TCG) standard
  • Microsoft Crypto API and PKCS#11 software interface support
  • RSA Secured Partner program certification
Full functionality of the TPM Embedded Security Chip is available only with Microsoft Windows XP Professional.
Optional Features
Biometric sensor for fingerprint authentication, configurable between Touchpad pick buttons.
For more information on HP security solutions, refer to the Security Solutions page on HP website.
Power Supply
  • External 90 watt AC adapter, 6 foot (1.8 m) power cord included.
  • Total length including External AC adapter is 12 feet (3.66 m).
  • HP Fast Charge technology
Battery
Primary Battery
Battery Life
Primary Battery
Up to 4 hours
Primary Battery and optional HP 8-Cell Extended Life Battery
Primary Battery and optional HP 12-Cell Ultra-Capacity Battery
Up to 10 hours
Battery life will vary depending on the product configuration, product model, applications loaded on the product, power management settings of the product, and the product features used by the customer. As with all batteries, the maximum capacity of this battery will decrease with time and usage.
System Standby Time
Up to one week
Power Conservation
  • Supports enhanced Intel SpeedStep technology with Intel Core Duo processors (allows Battery Optimized Mode, Maximum Performance Mode, or Automatic mode)
  • HP Smart Power NIC technology
  • ATI PowerPlay technology
  • Hibernation
  • Standby
  • ACPI compliance
Docking
  • HP Docking Station
  • HP Advanced Docking Station
HP's shared docking solutions provide simple and convenient port replication and cable management. Features include Gigabit NIC pass through, modem pass through, legacy parallel and serial ports, DVI, S-video TV out, USB 2.0 ports, integrated security mechanism5, integrated MultiBay II and ExpressCard6 slots. These docking solutions are compatible across multiple Business Notebook platforms enabling a lower total cost of ownership.
Note 5: HP/Kensington Cable Lock required (purchased separately)
Note 6: HP Advanced Docking Station only
Audio Specifications
Item
Specification
Implementation
ADI1981HD High Definition CODEC
Volume Controls
Up, down, and mute buttons
Full Duplex
Yes
Yes
Microphone Jack
Stereo or mono
Headphone/Line Out Jack
Stereo
Audio Output Quality
Frequency Response
20 Hz – 20 kHz
Signal to Noise Ratio
> 85 dB
Total Harmonic Distortion
0.01%
Noise Floor
-110 dB
Play/Record Sampling Rate(s)
8 kHZ – 48 kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Internal Speakers
Power Rating
2 Watts
Impedance
4 Ohms
Display Specifications
17.0-Inch Color TFT WXGA+ Display
Item
Specification
Dimensions (W x H)
38.2 cm x 24.5 cm (15.0 x 9.6 inches)
Diagonal Size
431.8 mm (17.0 inches)
Surface Treatment
Anti-glare
Number of Colors
Up to 16M
Contrast Ratio
300:1 typical
Refresh Rate
60 Hz
Brightness
150 nit typical
Pixel Resolution
Pitch
0.255 mm
Format
1440 x 900
Configuration
RGB Stripe
Backlight
CCFL
PPI
99
Viewing Angle
17.0-Inch Color TFT WSXGA+ Wide Viewing Angle Display
Item
Specification
Dimensions (W x H)
Diagonal Size
43.2 cm (17.0 inches)
Surface Treatment
Anti-glare
Number of Colors
Up to 16M
Contrast Ratio
300:1 typical
Refresh Rate
60 Hz
Brightness
180 nit typical
Pixel Resolution
Pitch
0.218 mm
Format
1680 x 1050
Configuration
RGB Stripe
Backlight
CCFL
PPI
116
Viewing Angle
±75° degrees Horizontal, ±60° degrees Vertical (typical)
17.0-Inch Color TFT WUXGA Wide Viewing Angle Display
Item
Specification
Dimensions (W x H)
38.2 cm x 245 cm (15.0 x 9.6 inches)
Diagonal Size
Surface Treatment
Anti-glare
Number of Colors
Up to 16M
Contrast Ratio
300:1 typical
Refresh Rate
60 Hz
Brightness
180 nit typical
Pixel Resolution
Pitch
0.191 mm
Format
1920 x 1200
Configuration
RGB Stripe
Backlight
CCFL
PPI
133
Viewing Angle
±65° degrees Horizontal, ±50° degrees Vertical (typical)
17.0-Inch Color TFT WSXGA+ Wide Viewing Angle BrightView Display
Item
Specification
Dimensions (W x H)
Diagonal Size
Surface Treatment
BrightView
Number of Colors
Up to 16M
Contrast Ratio
300:1 typical
Refresh Rate
60 Hz
Brightness
180 nit typical
Pixel Resolution
Pitch
0.218 mm
Format
1680 x 1050
Configuration
RGB Stripe
Backlight
CCFL
PPI
116
Viewing Angle
Electrical Specifications
Item
Specification
90W External AC Adapter
  • 0.37 kg (0.82 lb) (adapter)
  • 0.13 kg (0.29 lb) (power cord)
Dimensions
12.7 cm x 5.0 cm x 2.9 cm (5.00 x 1.97 x 1.1 inches)
Input
Operating Input Voltage
100 to 240 VAC
Operating Input Current
PFC Version:
  • 1.5 A at 90 VAC
  • 0.75 A at 180 VAC
Non-PFC Version:
  • 2.4 A at 90 VAC
  • 1.2 A at 180 VAC
Operating Frequency Range
47 to 63 Hz AC
Efficiency
83% minimum at 115 VAC
Output
Output Power
90 Watts
DC Output Voltage
18.5 Volts
Environmental
32° degrees to 104° degrees F (0° degrees to 40° degrees C)
Non-operating (storage) Temperature
-4° degrees to 149° degrees F (-20° degrees to 65° degrees C)
Altitude
0 to 10,000 feet (0 to 3,048 m)
Humidity
20% to 80%
Storage Humidity
10% to 90%
EMI and Safety Certifications
  • CE Mark: full compliance with LVD and EMC directives
  • Worldwide safety standards: IEC60950, EN60950, UL60950, Class2, SELV
  • Agency approvals: C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE, S-Mark, Australian Electric Permit, PSB, eK, BSMI, BNCI, KONCAR, GS, GOST, SASO, SABS, UKRSERTCOMPUTER
Approvals in italics apply to PFC version only.
MTBF
Over 200,000 hours at 25° degrees C ambient condition
Dimensions (H x W x L)
3.33 cm x 15.25 cm x 26.88 cm (1.3 x 6.0 x 10.6 inches)
0.803 kg (1.77 lb)
Cells/Type
12-cell Lithium-Ion
Energy
Voltage
14.4 Volts
Watt-hour Capacity
95Wh
Amp-hour Capacity
6.6Ah
Temperature
Operating (Charging)
32° degrees to 113° degrees F (0° degrees to 45° degrees C)
Operating (Discharging)
14° degrees to 140° degrees F (–10° degrees to 60° degrees C)
Non-operating
–4° degrees to 140° degrees F (–20° degrees to 60° degrees C)
Battery Re-Charge Time
Smart Adapter
3 to 4 hours
System ON
4 to 5 hours (depending on system power consumption)
Fuel Gauge
When pressed, LEDs light indicating level of charge remaining on battery
2.5 cm x 10.0 cm x 22.0 cm (1.0 x 3.9 x 8.7 inches)
0.455 kg (1.00 lb)
Cells/Type
8-cell Lithium-Ion
Energy
Voltage
14.4 Volts
Watt-hour Capacity
52Wh
Amp-hour Capacity
3.6Ah
Temperature
Non-operating
System in OFF mode or Standby
3 hours
System ON
3 to 5 hours (depending on system power consumption)
Fuel Gauge
69Wh Primary 8-Cell Battery
2.0 cm x 4.8 cm x 27.0 cm (0.8 x 1.9 x 10.6 inches)
0.445 kg (0.980 lb)
Cells/Type
8-cell Lithium-Ion
Energy
Voltage
14.4 Volts
Watt-hour Capacity
69Wh
Amp-hour Capacity
4.8Ah
Temperature
Non-operating
2.5 hours
System ON
HP Fast Charge Technology
Charges the battery up to 90% within 1.5 hours when system is OFF
Communications Specifications
Integrated Broadcom NetXtreme Gigabit Ethernet PCI Express Controller (BCM5753M)
Item
Specification
Ethernet Features
  • 10 Mbit/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mbit/s operation (1000BASE-T; IEEE 802.3z and 802.3ab; IEEE 802.3 clauses 34-42)
  • Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mbit/s
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
Power Management
  • ACPI compliant -- multiple power modes
  • Situation-sensitive features reduce power consumption
  • NIC Battery Saving Mode (enabled by default)
Performance Features
  • TCP/IP/UDP Checksum Offload (configurable)
  • TCP Segmentation Offload
  • CPU Task Offload
  • Adaptive Interrupts
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame);
  • Wake-on-LAN from off (Magic Packet only)
  • PXE 2.1 Remote Boot
  • Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite Cable Analyzer
Interface
PCI Express x1
NIC Device Driver Name
Drivers Available
  • Microsoft Windows XP
  • Microsoft Windows 2000
V.92 56K Data/Fax Modem
Item
Specification
Form Factor
MDC 1.5 Daughtercard
Power Management Support
APM Revision 1.2, ACPI
Approvals/ Certifications
UL, CSA, NEMKO, CCIB, Industry Canada, FCC Part 68, CTR21, FCC Part 15 Class B, Canadian ICES-003 Class B, C.I.S.P.R.22, Australian ACA, CE Mark, Other Countries
Data Mode Capabilities
V.92 data
V.8bis
V.80
V44, V.42bis, MNP5 (Compression)
V.42 (LAPM, MNP2-4) (Error Correction)
Optional symbol rates: 2800, 3429 Asymmetric Symbol rates
Synchronous primary channel data signaling rates:
  • 3600, 31200
Automatic rate re-negotiation
  • V.34
  • V.32bis
  • V.32
  • V.23
  • V.22bis
  • V.22
  • V.21
  • Bell 212A
  • Bell 103J
Fax Mode Capabilities
  • TIA/EIA-578-B (Class 1)
  • T.30, T.4 (Group 3)
  • V.17
  • V.29
  • V.27ter
  • V.21 Channel 2
Command Set
  • V.250 (Partial)
  • TIA-602
  • Identification: +GMI, +GMM, +GMR
  • Port control: +IPR, +ICF, +IFC, +ILRR
  • Modulation: +MS, +MR, +MA
  • Error control: +ES, +ER, +EB, +ESR, +ETBM
  • Data compression: +DS, +DR
  • V.251
Broadcom 4311AG 802.11a/b/g WiFi Adapter
Item
Specification
Wireless LAN Standards
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
Interoperability
  • Wi-Fi certified
  • Cisco Compatible Extensions Program compliant
Frequency Band
2.4 GHz and 5 GHz
Data Rates
802.11b: 1, 2, 5.5, 11 Mbps
802.11a/g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
Modulation
Direct Sequence Spread Spectrum
DBPSK, DQPSK, CCK, OFDM
Security1
Supports 64-bit and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST, EAP-SIM
Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 4)
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations
Media Access Protocol
CSMA/CA (Collision Avoidance) with ACK
Network Architecture Models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between access points
Output Power (for CKK)2
17.5 dBm
Output Power (for OFDM; power varies by data rate)2
15 dBm
Power Consumption
  • Transmit: 2.0 Watts (max)
  • Receive: 1.5 Watts (max)
  • Idle mode3: 390 mW (nominal)
  • Sleep mode: 20 mW (max)
Power Management
ACPI compliant power management
802.11 compliant power saving mode
Receiver Sensitivity4
  • 54 Mbps: -72 dBm
  • 11 Mbps: -88 dBm
  • 1 Mbps: -97 dBm
Antenna type
High efficiency dual band antenna with spatial diversity, mounted in the display enclosure
Range
802.11 a – Typical (@6 Mbps)
600 feet – Outdoor Open Area
150 feet – Indoor, Office environment
802.11 b – Typical (@1 Mbps)
1200 feet – Outdoor Open Area
300 feet – Indoor, Office environment
802.11 g – Typical (@1 Mbps)
Form Factor
PCI-Express MiniCard
12 g (0.026 lb)
Dimensions
4.75 mm x 29.85 mm x 50.8 mm (0.19 x 1.2 x 2.0 inches)
Operating Voltage
3.3 Volts +/- 10%
Temperature
Operating
32° degrees to 176° degrees F (0° degrees to 80° degrees C)
Non-operating
-40° degrees to 176° degrees F (-40° degrees to 80° degrees C)
Humidity
Operating
10% to 90% (non-condensing)
Non-operating
5% to 95% (non-condensing)
Altitude
Operating
0 to 10,000 feet (3,048 m)
Non-operating
0 to 50,000 feet (15,240 m)
Configuration Utility5
Choice of Configuration Utility:
  • Microsoft Windows XP Wireless Network Connection Manager
  • Broadcom Wireless Configuration Utility (required for Cisco Compatible Extensions support)
LED Activity
LED Off – Radio OFF
Solid LED On – Radio ON
Note 1: Check latest software/driver release for updates on supported security features.
Note 2: Maximum output power may vary by country according to local regulations.
Note 3: In Power Save Polling mode.
Note 4: Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CKK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
Note 5: WLAN supplier's client utility is required for Cisco Compatible Extensions support. WLAN may also be compatible with certain third-party software supplicants.
Broadcom 4311BG 802.11b/g WiFi Adapter
Item
Specification
  • IEEE 802.11b
  • IEEE 802.11g
Interoperability
  • Wi-Fi certified
Frequency Band
2.4 GHz
Data Rates
802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
Modulation
Security1
Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 4).
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Roaming
17.5 dBm
15 dBm
Power Consumption
Transmit: 2.0 W (max)
Receive: 1.5 W (max)
Power Management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
  • 54 Mbps: -72 dBm
  • 11 Mbps: -88 dBm
  • 1 Mbps: -97 dBm
Antenna type
Range
Form Factor
12 g (0.026 lb)
Dimensions
Operating Voltage
3.3 Volts +/- 10%
Temperature
Operating
Non-operating
Humidity
Operating
Non-operating
Altitude
Operating
Non-operating
LED Activity
LED Off – Radio OFF
Intel PRO/Wireless 3945ABG 802.11a/b/g Network Connection
Item
Specification
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
Interoperability
  • Wi-Fi certified
Frequency Band
2.4 GHz and 5 GHz
Data Rates
Modulation
Security1
Supports 64-bit and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST, EAP-SIM.
Sub-channels
Roaming
15 dBm
15 dBm
Power Consumption
Transmit: 1.8 Watts (max)
Receive: 1.4 Watts (max)
Idle mode3: 150 mW (nominal)
Sleep mode: 30 mW (max)
Power Management
  • 54 Mbps: -72 dBm
  • 11 Mbps: -88 dBm
  • 1 Mbps: -97 dBm
Antenna type
Range
Form Factor
6 g (0.013 lb)
Dimensions
Operating Voltage
3.3 Volts +/- 10%
Temperature
Operating
Non-operating
Humidity
Operating
Non-operating
Altitude
Operating
Non-operating
  • Intel PROSet (required for Cisco Compatible Extensions support)
LED Activity
LED Off – Radio OFF
Intel PRO/Wireless 3945BG 802.11b/g Network Connection
Item
Specification
  • IEEE 802.11b
  • IEEE 802.11g
Interoperability
  • Wi-Fi certified
Frequency Band
2.4 GHz
Data Rates
Modulation
Security1
Sub-channels
Roaming
15 dBm
15 dBm
Power Consumption
Power Management
  • 54 Mbps: -72 dBm
  • 11 Mbps: -88 dBm
  • 1 Mbps: -97 dBm
Antenna type
Range
Form Factor
6 g (0.013 lb)
Dimensions
Operating Voltage
3.3 Volts +/- 10%
Temperature
Operating
Non-operating
Humidity
Operating
Non-operating
Altitude
Operating
Non-operating
LED Activity
LED Off – Radio OFF
HP Integrated Module with Bluetooth Wireless Technology
Item
Specification
2.0 Compliant
Dimensions
26 mm x 14 mm x 5.7 mm (1.02 x 0.55 x 0.22 inches)
Frequency Band
2402 to 2480 MHz
Number of Available Channels
79 (1 MHz) available channels
Data Rates and Throughput
3 Mbps data rate; throughput up to 2.17 Mbps
Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
Asynchronous Connection Less links 2178.1 kbps/177.1 kbps asymmetric or 1306.9 kbps symmetric
Transmit Power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBM at 0.1 % raw bit error rate
Power Consumption
  • Peak (Tx) 264 mW
  • Peak (Rx) 231 mW
  • Sleep < 1 mW
Antenna
Internally integrated within module
Range
Up 33 feet (10 m)
Electrical Interface
USB 2.0 compliant
Microsoft Windows Plug and Play compliant
OS Support
  • Microsoft Windows XP Professional and Home
Bluetooth Software Supported
  • Broadcom Bluetooth for Windows
  • Microsoft Windows XP Bluetooth Software
Link Topology
Point to Point, Multipoint Piconets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Power Management
Microsoft Windows ACPI
USB Bus Support
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Temperature
Operating
-4° degrees to 158° degrees F (-20° degrees to 70° degrees C)
Non-operating
Humidity
Operating
10% to 90%
Non-operating
5% to 95%
Altitude
Operating
15,000 feet (4,572 m)
Non-operating
40,000 feet (12,192 m)
Bluetooth Profiles Supported
(with Bluetooth for Windows 4.0 software)
  • Serial Port Profile (SPP)1
  • Dial-Up Networking (DUN)1
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)1
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)1
  • Personal Area Networking Profile (PAN)1
  • Human Interface Device Profile (HID)1
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Advanced Audio Distribution Profile (A2DP)
Note 1: Indicates the profile is also supported by Microsoft Windows XP SP2
Physical Specifications
Item
Specification
Dimensions (HxWxD)
33 mm (at front) x 393 mm x 275 mm (1.3 (at front) x 15.5 x 10.8 inches)
3.36 kg (7.4 lb)
Height varies depending upon where on the notebook the measurement is made. Weight includes 8-cell battery, 60 GB hard drive, 512 MB memory, 802.11 wireless communications module, and TPM Embedded Security Chip. Weight varies by configuration and components.
Software/OS
Feature
Preinstalled
FreeDOS
Supported Microsoft Windows 2000
Drivers downloadable from http://www.hp.com
Certified
Preinstalled Software Microsoft Windows XP
Adobe Acrobat Reader
HP Backup and Recovery Manager
HP Help and Support
HP Mobile Print Driver
HP ProtectTools
Security Manager: BIOS Configuration for HP ProtectTools
Embedded Security for HP ProtectTools
Credential Manager for HP ProtectTools
Smart Card Security for HP ProtectTools
HP Quick Launch Buttons
HP Wireless Assistant
Sonic Digital Media Plus: RecordNow! (for optional DVD+/-RW and DVD/CDRW drives)
MyDVD (DVD Authoring for optional DVD+/-RW drives)
Synaptics Touchpad Driver
Symantec Norton Internet Security with complimentary 60-day live update
Intervideo WinDVD - DVD Player (for optional DVD+/-RW, DVD/CDRW and DVD drives)
Each unit is shipped with HP Backup and Recovery Manager. HP Backup and Recovery Manager can provide data and system file protection for HP business PCs to enable fast recovery if the system becomes corrupted or if important information is accidentally deleted. HP Backup and Recovery Manager can perform scheduled or manual backups of the entire drive or individual files and folders. Up to 8GB is reserved for the system recovery software. HP Backup and Recovery Manager can also create software recovery CDs or DVDs (requires optional hardware).
SMBIOS Version 2.4
System Management BIOS, previously known as DMI BIOS, is used to store system management information.
HP ProtectTools Security Manager is the security platform for business notebooks and desktops. The HP ProtectTools Security Manager is an extensible client security console that delivers enhanced security capabilities through add-on software modules. Modules currently available or planned are:
  • Smart Card Security for HP ProtectTools
  • BIOS Configuration for HP ProtectTools
  • Embedded Security for HP ProtectTools
  • Credential Manager for HP ProtectTools
Environmental Specifications
Item
Specification
Stand-Alone Power Requirements
Nominal Operating Voltage
19 Volts
Average Operating Power
25 Watts
Max Operating Power
< 90 Watts
Temperature
Operating
  • 32° degrees to 95° degrees F (0° degrees to 35° degrees C) (not writing optical)
  • 41° degrees to 95° degrees F (5° degrees to 35° degrees C) (writing optical)
Non-operating
-4° degrees to 140° degrees F (-20° degrees to 60° degrees C)
Relative Humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 101.6° degrees F (38.7° degrees C) maximum wet bulb temperature
Shock
Operating
125 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random Vibration
Operating
0.75 grms
Non-operating
1.50 grms
Altitude (unpressurized)
Operating
-50 to 10,000 feet (-15.24 to 3,048 m)
Non-operating
-50 to 40,000 feet (-15.24 to 12,192 m)
Industry Standard Certifications
Certified
Blue Angel
No
UL
Yes
Energy Star Compliant
Yes
CSA
Yes
ICES
Yes
GS
Yes
Australia / NZ A-Tick Compliance
Yes
CCC
Yes
Japan VCCI Compliance
Yes
MIC
Yes
BSMI
Yes
CE Marking Compliance
Yes
BNCI or BELUS
Yes
Croatian Compliance (CIT)
Yes
GOST
Yes
Saudi Arabian Compliance (ICCP)
Yes
SABS
Yes
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
