HP LaserJet 1018 and 1018s Printers - Setting up the LaserJet (Hardware)
  • Unpack the printer and check the contents
  • Remove the packing tape and install the paper guide
  • Install the print cartridge
  • Connect the power cord
  • Turn on power
  • Load plain paper
Setting up the printer
Follow these steps in order.
Step one: Unpack the printer and check the contents
  1. Remove the product from the box.
    Figure : Remove the product from the box
    Illustration: Remove the product from the box
  2. Check the contents of the box.
Step two: Remove the packing tape and install the paper guide
  1. Open the paper tray.
    Figure : Open the paper tray
    Ilustration: Open the paper tray
  2. Remove all the orange packing tape from the product.
    Figure : Remove the packing tape
    Illustration: Remove the packing tape
  3. Install the output paper guide.
    Figure : Install the output paper guide
    Illustration: Install the output paper guide
Step three: Install the print cartridge
  1. Open the print cartridge door.
    Figure : Open the print cartridge door
    Illustration: Open the print cartridge door
  2. Remove the print cartridge from the packing material, and then rotate the print cartridge back-and-forth approximately five times to mix the toner.
    Figure : Remove the print cartridge and rotate
    Illustration: Remove the print cartridge and rotate
  3. Remove the sealing tape from the print cartridge.
    Figure : Remove the sealing tape
    Illustration: Remove the sealing tape
  4. Insert the print cartridge, and then close the print cartridge door.
    Figure : Insert the print cartridge and close the door
    Illustration: Insert the print cartridge and close the door
Step four: Connect the power cord
Connect the power cord to the back of the product, and then plug the power cord into an electrical outlet.
Figure : Connect the power cord
Illustration: Connect the power cord
Step five: Turn on power
Press the Power switch to turn on the product.
Figure : Press the Power switch
Illustration: Press the Power switch
Step six: Load plain paper
  1. Slide the paper width and length guides to their outmost positions.
    Figure : Slide out the paper guides
    Illustration: Slide out the paper guides
  2. Load the paper into the paper tray, and then slide the paper width and length guides inward until they stop at the edge of the paper.
    Figure : Load the paper and slide in paper guides
    Illustration: Load the paper and slide in paper guides.
Country: Flag Bulgaria
