    Windows 11 Upgrade Guide
HP iPAQ rx1950 Pocket PC - Specifications
System Specifications
Feature
Specification
Processor
Samsung® SC32442 300 MHz Processor
Memory (User Available Memory)
96 MB total memory (64 MB ROM and 32 MB SDRAM)
Up to 33 MB user available persistent storage memory
Type Transflective TFT QVGA color with LED backlight with power save mode
Number of Colors 64K color (65,536 colors) 16-bit
Touch Screen
Resolution (W x H) 240 x 320 pixels
Dot Pitch 0.24 mm
Viewable Image Size 3.5 in (89 mm) diagonal
Hardware Buttons/ Reset Buttons
One power button, one recording button, one soft reset switch, four software programmable AP buttons, one 5-way joy stick
Stylus
One – Included in the box
Audio
Integrated microphone, speaker and one 3.5 mm stereo headphone jack
Indicators
Alarms
  • Solid amber LED (right) – battery in unit fully charged
  • Flashing amber LED (right) – battery in unit is charging
  • Flashing green LED (right) – event alarm/notification
  • Solid Blue LED (left) – WiFi active
Notification - Sound and visual message on the display
Cradle Interfaces (Cradle available as optional accessory)
Connector - (1) 22 pin connector for synchronization and charging
Cable - (1) USB cable connects to PC
(1) DC Power jack connector for AC/DC Adapter connection
Integrated Spare battery charger Charge additional slim or extended battery
Other Interfaces
IrDA (SIR)
USB 1.1 Client – supported via HP standard 22-pin sync connector interface
Serial RS232 – supported via HP standard 22-pin cable interface (cable must be purchased separately)
Some HP authorized options may not be supported. See http://www.hp.com/go/ipaqaccessories.
SD Slot
Support 1-bit/4-bit SDIO, SD/MMC type memory standard, and mini SD memory cards with SD adapters
Power Supply
Battery - Removable/rechargeable 1100 mAh Lithium-lon (user changeable). Optional extended 1800 mAh Lithium-lon battery available for purchase (http://www.hp.com/go/ipaqaccessories).
AC Power - AC Input: 100~240 Vac, 50/60 Hz, AC Input current: 0.3 Aac max Output Voltage: 5Vdc (typical), Output Current: 2A (typical)
Battery run time varies based on the usage pattern of an individual user and the configuration of the handheld. Use of internal wireless capabilities and backlight will significantly decrease battery run time.
AC Adapter
Dimensions (H x W x D) - 3 x 1.9 x 1.8 in (76 x 48 x 44 mm - including prongs), (may vary by model)
Cord Length - 6 ft (1.83 m)
Power Supply Ratings
Voltage Range 100 to 240 V
Switching Input Current 0.4 A ac
Input Frequency 50 to 60 Hz
Output Voltage 5 V DC
Output Current 2 Amp
System Unit
Dimensions (H x W x D) - 4.47 x 2.78 x 0.5 in (113.6 x 70.6 x 13.5 mm)
Weight - 4.4 oz (125 g)
Operating Temperature 32° to 104° F (0° to 40° C)
Storage Temperature -4° to 140° F (-20° to 60° C)
Operating Humidity 90% RH
Regulatory Marks
  • Electrical - FCC Class B, UL or CSA NRTL, CE
  • Safety - C-UL, NOM
Design Features
4 programmable application quick-launch buttons, 5-way navigation joystick, touch-sensitive display for stylus or fingertip, voice record button, microphone and speaker
Operating System
Microsoft® Windows Mobile™ 5.0 for Pocket PC, Premium Edition
Mobile versions of Microsoft software are included (Word®, Excel®, PowerPoint® and Internet Explorer®)
Microsoft® Outlook™ 2002 for Pocket PC
Operating System Applications
Powered by Microsoft® Windows Mobile™ Version 5.0 for Pocket PC, Premium Edition; Calendar, Contacts, Messaging (with Spell Checker for email), Tasks, Voice Recorder, Notes, Word® Mobile (with Spellchecker), Excel® Mobile, PowerPoint® Mobile, Internet Explorer Mobile, Windows Media Player 10 Mobile, Calculator, Solitaire, Jawbreaker, File Explorer, Pictures and Videos, Terminal Services Client, Beam, Clock, Align Screen, Memory, Volume.
In the box
HP iPAQ rx1950 Pocket PC, lithium-lon 1100 mAh removable/rechargeable battery, AC adapter, USB desktop synchronization cable, slip case, Documentation Package and HP iPAQ Getting Started disc
Additional Software and links
Microsoft ActiveSync 4.0 and links to Microsoft websites for additional downloadable applications
Some programs may require purchase of additional desktop software to utilize Pocket PC versions.
Service and Support
US Retail: 90 Days parts and labor. 90 days technical support for software in most regions.
Rest of World: One-year parts and labor; 90 days technical support for software in most regions. Additional offers may vary by region.
HP Exclusive Applications
iPAQ Wireless: manage your wireless connections
Pocket Panel Lite: one touch access from Today Screen to device status; battery, memory, backlight settings
iPAQ Entertainment
Utilities: Self Test, iPAQ Audio, Power Status, Backlight Applet, Certificate Enroller
Getting Started Disc from HP
Active Sync (Full Version)
Adobe Acrobat Reader for PC (Full Version)
Microsoft Outlook 2002 (Full Version)
CD Links Handango
Additional Documentation Important Safety Information on PDF, and Additional Product Information on PDF
Programs may vary based on model. Some programs are accessed through CD links to download web sites.
WiFi (802.11b) Specifications
Feature
Specification
Technology
High-speed wireless access to the Internet, email and corporate data
RF Network Standard
IEEE 802 Part 11b (802.11b)
Frequency Band
2.4000 to 2.4835 GHz
2.4465 to 2.4835 GHz (France)
2.4000 to 2.497 GHz (Japan)
Antenna type
Embedded Antenna
Security
WEP 64/128-bit compliant to IEEE 802.11
Compliant to 802.1X (EAP-TLS, PEAP)
WPA
Network Architecture Models
Ad-hoc (Peer to Peer)
Infrastructure (Access Points Required)
Modulation Technique
Direct Sequence Spread Spectrum
Modulation Schemes
DBPSK, DQPSK, CCK
Receiver Sensitivity – Packet Error Rate (8E-2)
11Mbps: <- 80 dBm
5.5 Mbps: <- 82 dBm
2 Mbps: <- 86 dBm
1 Mbps: <- 89 dBm
Maximum Receive Level
-10dBm (1/2/5.5/11 Mbps)
Output Power
15 dBm
Power Consumption
Transmit mode: 1.33 Watts, typical
Receive mode: 1.235 Watts, typical
Media Access Protocol
CSMA/CA (Collision Avoidance) with ACK
Protocols Supported TCP/IP IPX/SPX UDP
Operating Distance
Up to 1000 feet – Open sight
Certifications
All necessary regulatory approvals for countries we support including:
WECA
Wi-Fi approval
FCC (47 CFR) Part 15C, Section 15.247&15.249
ETS 300 328,
ETS 301
489-6 Low Voltage Directive IEC950
UL
CSA
CE Mark
  1. A standard WLAN (Wi-Fi) infrastructure, separately purchased equipment, and a service contract with a wireless airtime provider may be required for applicable wireless communication. Wireless Internet use requires a separately purchased service contract. Check with wireless network service providers for availability and coverage in your area. Not all web content available.
  2. Wireless access points required and are not included. Availability of public wireless access points limited. Wireless Internet use may require separately purchased Internet service contract.
