    Apache Log4j Update
HP L1506 Flat Panel Monitor - Overview
Product Description
The HP L1506 Flat Panel Monitor is a stylish, business-oriented 15-inch flat panel monitor that delivers essential performance features at competitive prices for small-to-medium businesses and mainstream corporate environments.
Product Features
Features
Type
Thin-Film Transistor (TFT)
Cabinet Color
Carbon/Silver
Size / Viewable Image Size (diagonal)
38 cm (15 in) maximum viewable
Native Resolution
1024 x 768 @ 60 Hz
Signal Input
15-pin D-sub (analog VGA)
Horizontal Viewing Angle
130 degrees
Vertical Viewing Angle
100 degrees
Image Quality
Brightness (typical)
250 nits (cd/m2)
Contrast Ratio (typical)
450:1 (typical)
Pixel Pitch
0.297 mm
Horizontal Frequency Range
30 to 61 kHz
Vertical Frequency Range
56 to 76 Hz
Ease of Use
User Programmable Modes
10
Plug and Play
Yes
On-Screen Controls
Image Control (auto, horizontal, vertical), Positioning (vertical and horizontal), Color Temperature (6500k, 9300k, Custom), Brightness, Contrast, Clock, Clock Phase, Monitor Management (power saver, sleep), Factory Reset
Language Selection
Yes
Asset Control
Yes
Resolution
1024 x 768
60 Hz, 70 Hz, and 75 Hz
800 x 600
60 Hz, 72 Hz, and 75 Hz
640 x 480
Ergonomic Features
Anti-Glare/Anti-Static
Yes/Yes
Tilt/Swivel
Yes/No
Tilt Angle
-5 degrees to +30 degrees
Approvals / Certifications
MPR-II Compliant
Yes
ISO 9241-3,7,8 VDT guidelines, ISO 13406-2 pixel defect guidelines
Yes
Energy Star Compliant
Yes
FCC Approval
Yes
TCO '99 Certified
Yes
UL Approval
Yes
Hardware Features
Sync Input
TTL separate synch
Dimensions without stand (HxWxD)
35.5 x 34.0 x 20.3 cm (13.9 x 13.4 x 7.9 in)
Weight unpacked
3.2 kg (7.05 lb)
Weight packaged
4.5 kg (9.92 lb)
Accessories
Attached VGA cable, AC power cable
Service and Support
3/3/3 including backlight (Parts/Labor/On-Site)
Software Overview
HP Display LiteSaver
HP Display LiteSaver feature allows you to schedule Sleep mode at preset times to help protect the monitor against image retention, drastically lower power consumption and energy costs, and extend the lifespan of the monitor.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
